abs light flashing
Old Apr 9, 2010 | 03:04 PM
jlgbldr's Avatar
jlgbldr
Unhappy abs light flashing
Ihave a 2002 excursion and the abs light keeps flashing on and off when this happens the engine misses and speedo falls off and at and idle when cold the truck will stall then od light will flash have change both rear diff and tailshaft speed sensors and am still having same problem am looking for a place ar direction to go the truck quit other day and engine light came on the code showing is P0720
Old Apr 11, 2010 | 12:35 AM
Rickx's Avatar
Rickx
<TABLE border=1 cellSpacing=0 cellPadding=3><TBODY><TR><TD vAlign=top align=left>P0720 - Insufficient input from Output Shaft Speed sensor </TD><TD vAlign=top align=left>The output shaft speed sensor inputs a signal to the PCM, based on the speed of the output shaft of the transmission. The PCM compares this signal with the signal of the VSS or TCSS and determines correct tire size and axle gear ratio. </TD><TD vAlign=top align=left>
  • OSS sensor circuit short to GND
  • OSS sensor circuit short to PWR
  • OSS sensor circuit open
  • Damaged OSS sensor
  • Damaged PCM
</TD><TD vAlign=top align=left>Verify sensor signal output varies with vehicle speed. </TD></TR></TBODY></TABLE>
Old Apr 15, 2010 | 07:54 AM
jlgbldr's Avatar
jlgbldr
Hi Rickx
So you are saying that I should check the list of sensor problems you have listed and also how do I verify sensor output to speed. I did have one shop tell me that it could be a ground problem any idea where I should start and would a digram of speed sensor help also any idea where I could get one.
Thanks
Jlgbldr
Old Jan 16, 2011 | 04:24 PM
excursiondude's Avatar
excursiondude
Did you ever figure this out? I am having the same problem
Thanks
Dave
tmartin2
Jul 19, 2011 11:05 AM
Fordff550e
Aug 10, 2010 10:23 AM
katruck
Mar 24, 2009 08:44 AM
jayhawkfan
1983 - 2012 Ranger & B-Series
Feb 19, 2004 03:29 PM
Aegerter36
May 8, 2003 10:39 PM
