A/C weak in Freestar
Find the AC compressor under the hood. If you don't know what is what, this is the belt-driven accessory that has a pulley that typically looks like it has 3 low ***** on it. That's the clutch plate. It helps to do this when the weather is warm - at least 60F - so that the system has enough pressure to operate correctly. Low temps= low freon pressures, and the system won't run as it trips the low pressure cut-out switch. Start the car, put it on MAX AC to ensure the compressor will run (give it 10 sec to make sure it kicks on). Now go look at the compressor. Is the clutch turning with the pully or is it stationary? If it is not turning, give it a tap on the front face of it (towards the pulley) with a screwdriver handle or broom handle or stick. OBVIOUSLY you need to be careful not to get anything (tool/hand/hair/etc) caught in a belt or pulley when you do this. If the clutch suddenly engages when you do this, then the clutch gap is too wide from wear over time. The fix is to pull the clutch and remove one of the clutch shims on the compressor shaft to tighten up the gap and bring it back in spec again so it works. That is easy to do.
You need to hold the clutch still so it does not turn. Wedging it with a pry bar or something helps. Remove the center nut/bolt and then use a couple screwdrivers or flat bars to pry the clutch off by working around it in a few places bit by bit. You will see a couple thin small washers on the shaft - they might be hidden up in the clutch or on the compressor - depends on the model. Typically removing one of them will do the trick. Normal clutch gap is 0.014-0.030" (But that does vary slightly by model). If there is a really thin one and a thicker one, you probably want to pull the thicker one. Reassemble and try it out.
Avoid sealants in AC systems. AC system testing requires a guage SET with 2 gages - low and high side. The "Magic In A Can" with a low pressure gage only, tells you very little.
Many Auto Zone stores will loan/rent a manifold gauge set. With that you can monitor both sides of the system and better determine the refrigerant charge
Obviously, if the system is low on refrigerant you have a leak that should be repaired. Leaks don't get "better". If the system is very low/empty of refrigerant, there may also be air in the system which can damage components. The system then needs to be pulled into a hard vacuum before charging.
There is much more to AC repair than "topping off" the refrigerant. Blindly adding refrigerant can cause expensive damage to a system that may only need a simple repair.
I'm a free market kind of guy, but if I were going to outlaw just ONE product, it would be a/c sealants. I have two recovery/recycle machines that are always only one recovery away from destruction should I recover from a system with that JUNK in it.
I just spent $800 to have my combo R12/R134a machine repaired due to sealer ingestion.
