1978 - 1996 Big Bronco
aaaahhhhhhhhhh
Old Apr 8, 2010 | 07:16 PM
deadeyedevon's Avatar
deadeyedevon
aaaahhhhhhhhhh
im so spooked to tow my trailer with my bronco, i dont wanna tear it up. its in tiptop shape but the trailer just looks so freakin big. any opinions?
Old Apr 8, 2010 | 07:39 PM
andym's Avatar
andym
What are you talking about?
Old Apr 8, 2010 | 07:42 PM
deadeyedevon
would you be comfortable pulling a 5K trailer with a 5.8 bronco?
Old Apr 8, 2010 | 07:49 PM
andym's Avatar
andym
*sigh*
What is the trailer? An RV? A car trailer? A landscaping trailer? Does it have brakes? What kind? Do you have a brake controller? What kind of terrain are you pulling it over? Do you have a tranny cooler? Do you have a receiver hitch?
Old Apr 8, 2010 | 07:52 PM
deadeyedevon
oooook,prodigy brake controller,tow package with class 3/4 hitch towing a RV trailer....
Old Apr 8, 2010 | 08:05 PM
mtufreerider's Avatar
mtufreerider
Build Ford Tough. You shouldn't have any bit of problem with trailer brakes. If you squat to low consider add-a-leaf for your next upgrade to the Bronco. We used to pull a 32' travel trailer behind a grand marque, a Bronco? no problem
Old Apr 8, 2010 | 11:03 PM
fordinlinesix's Avatar
fordinlinesix
Yeah, i tow my Ford 8N tractor w/rotary cutter and box blade on a 16' flatbed trailer all the time, never have any issues.
'90 Bronco 351/E4OD and 3.55 gears
Old Apr 9, 2010 | 12:16 PM
Kemicalburns's Avatar
Kemicalburns
get an ez lift hitch setup. this will help spread the load and make it much safer. do you still have your rear sway bar installed?
when you tow stay out of overdrive. also make sure you have a tranny cooler and that you have recently serviced the tranny.
Old Apr 9, 2010 | 09:26 PM
deadeyedevon
ive got a weight dist hitch and i recently serviced the tranny. i do have to check n the anti-sway bar. i thought that was part of the factory tow package?
Old Apr 9, 2010 | 09:29 PM
greystreak92's Avatar
greystreak92
It was... Kem just meant that having it there would be a good idea if you are towing. Many folks opt to remove the sway bars in favor of greater articulation for off-road conditions. This is especially true if the truck has a suspension lift.
Old Apr 9, 2010 | 09:30 PM
deadeyedevon
i got ya....
phantomphixer
All Things Towing
34
Jan 17, 2013 09:27 PM
lakewood
Apr 26, 2011 11:06 PM
htchief
Electrical Systems/Wiring
Jan 28, 2008 05:54 PM
alabbasi
17
Apr 16, 2007 06:54 PM
BASSHUNTER
Dec 14, 2006 04:05 PM
