Sponsored by: Real Truck
Lift block
Old Apr 8, 2010 | 03:40 PM
green250's Avatar
green250
Lift block
Hi guys,I have a 2000 ford f250 superduty 4x4 v10 with a 5.5" fabtech lift kit.
I currently run procomp springs in the rear and am going to put the stock springs back on for better ride quality.I am curious as to what size lift block fabtech uses on this lift with stock springs and if they use there lift block with the factory block or does it replace the factory block?If they use there block with the stock block i would like to just purchase one block to replace them both.
Thanks,
Steve
Old Apr 9, 2010 | 10:06 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
This will get a lot more answers in the Superduty forum. Thread moved
Old Apr 9, 2010 | 10:33 AM
Lubbockguy1979's Avatar
Lubbockguy1979
Lift blocks are not optimal. Stacking them is a recipe for disaster. The biggest issue with block is axle wrap. Just trying to help you info wise.
ccbrett
Oct 29, 2010 12:32 PM
deveaum
Sep 24, 2009 08:49 AM
jlmotox
Mar 24, 2009 10:06 AM
LJR
Nov 27, 2007 11:21 AM
lethalinjection
Mar 30, 2005 09:15 PM
