I am driving a 79 F250SC fromTampa to Maryland tomorrow. This is going to be a long drive as it has a 6" lift with 37" tires. I am pretty sure that the speedometer has not been calibrated after the 37's were put on so my question is: is there an equation to figure how fast I am going at a certain RPM? In other words if I run 3000 RPM I will be traveling at 65 MPH??
It has a 4.10 gear set with 37" tires. Oh and a 460
you need a calculator and fairly accurate way to measure seconds (stopwatch, etc).
Start the stopwatch at a milemarker, drive a constant speed, stop the stopwatch at the next milemarker. The stop watch will read the number of seconds to go 1 mile.
with the calculator, divide 1 by the number of seconds then multiply by 3600 to get MPH.
Here is a quick reference chart that will save you doing the calculation...you will just need to measure seconds to go one mile...
If you have mile markers on your route, use those to calculate your speed - just figure that, at 60mph, you're traveling 1 mile every minute - speed=distance/time.
do you have a gps? I have a hand held unit I use for hiking and you can map and mark yourself so when you want to go back it will tell you if you wander off coarse. It will also tell you how fast you are moving. I never know that but I have a teen aged son that showed me that in the car going down the highway. Got to love the kids as they know all of the electronic gismos. Hell, I still cant text on my phone.
Many years ago I made a spreadsheet to tell me just that. Here you go
The first and second gear speeds are calculated for the gear ratio's in my ford 3-spd, so if your trans is different, so too will the speeds. 3rd gear though is 1:1 and should be correct, unless of course you have overdrive. If you do, it will be wrong but can easily be fixed with the proper ratio.
