Tranny temps
Old Apr 7, 2010 | 10:09 PM
14psd's Avatar
14psd
Tranny temps
Hey any of ya'll know what temperature my transmission should be running at when I'm just cruzing down the highway at 70 mph. That's my normal speed. I have a 24,000lbs B&M tranny cooler. I have an Autometer gauge on it.
Old Apr 7, 2010 | 10:45 PM
JamesHajek's Avatar
JamesHajek
Whats the gauge say?
Old Apr 7, 2010 | 11:09 PM
oldbird1965's Avatar
oldbird1965
Do you have a thermostat?
Old Apr 8, 2010 | 05:32 AM
14psd's Avatar
14psd
the gauge has been reading any where from 180 to 210 and it hasn't even gotten hot here yet. Plus I haven't towed a heavy load yet. The transmission was rebuilt by a reputable shop and they flushed out the lines. I was there when they did that. The cooler was installed with the rebuild. I bought the cooler myself so I know which one they installed.
Old Apr 8, 2010 | 06:39 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Where is your sender installed?
Old Apr 8, 2010 | 05:44 PM
14psd's Avatar
14psd
On the driver's side of the transmission. Where the temperature sending unit is. Is there a better place to put it?
Old Apr 8, 2010 | 05:50 PM
TheTowingCowboy's Avatar
TheTowingCowboy
IDK but I thought you were spouse to install them in route cause installing them right at the tranny would read hotter cause of heat dispersal from the metal. IDK, just my thoughts.
Old Apr 8, 2010 | 07:39 PM
59JEEPSTANG's Avatar
59JEEPSTANG
Mine is installed on drivers side where a plug was located. Took p/u camper out last week and ran 65 to 70 on interstate temp ran about 160 (80 degrees outside, no hills).
Paul
Old Apr 8, 2010 | 07:57 PM
Mark Kovalsky
No. Installing the sender in the port on the driver's side of the trans is the best place. If you want to see the gauge move all over the place install it in the line to the cooler.
Old Apr 8, 2010 | 07:59 PM
Mark Kovalsky
I think there is a restriction in the cooler circuit. Is the radiator cooler still in the circuit? It could be plugged. If you bypassed it you may not have enough cooling to keep the trans cool.
Old Apr 8, 2010 | 09:46 PM
14psd's Avatar
14psd
The radiator cooler is still attached, I insisted that it remain. Can't have too much cooling on the transmission was my thought. Engine different story. I had the shop pressure flush the lines with out when the tranny was out. I was there for that.
Old Apr 10, 2010 | 06:57 AM
Mark Kovalsky
I suggest a flow test.
Get two buckets to catch ATF. Remove the line from the rear of the trans and aim it into the first bucket. Have someone start the engine and leave it in park at idle. Once the flow coming out of the line is steady move the line into the second bucket for exactly 15 seconds, the put it back in the first bucket and shut the engine off. If there is at least a quart in the second bucket there is enough flow.
