poor mileage
Old Apr 7, 2010 | 06:56 PM
kupaa's Avatar
kupaa
poor mileage
What would cause bad mileage,I'm only getting 12 mpg even before i did my injector swap.I drive slow most of the time.
Old Apr 7, 2010 | 07:43 PM
Fordbronco69's Avatar
Fordbronco69
Infidel
alota thing effect mileage...i was doing great before bellowed up-pipes, van turbo and Airdog, then went down around the 11-12 mark...changed oil back to dino Rotella and back up to 16ish~
Could be a sensor, dirty oil, brakes dragging...
Old Apr 7, 2010 | 07:46 PM
Izzy351's Avatar
Izzy351
What size tires are you running? On my stock 265s, I eeked out a little over 22 mpg on the highway. I average around 15 right now, but I don't drive it nice.
Old Apr 7, 2010 | 09:58 PM
kupaa's Avatar
kupaa
I'm running 33's but when i first got my truck in 06 I was getting 18 mpg even when i got my chip i still average the same miles.Then in 08 i started seeing a decline in mileage,i thought changing my injectors might help a little even if they are bigger.Today i did the math and it's 12 mpg.
Old Apr 7, 2010 | 10:56 PM
Fordbronco69
Infidel
Have you changed the CPS at all? Cleaned the EBPS and tube?
Old Apr 7, 2010 | 10:59 PM
kupaa's Avatar
kupaa
CPS yes,EBPV no
Old Apr 7, 2010 | 11:06 PM
Fordbronco69
Infidel
with a decline over time in mileage it might be that sensor, front of engine, right above water pump. its mounted on a light gauge steel peice and is flimsy. So when you take the sensor out make sure u got another wrench on the bottom of that steel piece where the tube connects to. Check the opening of the sensor, if its glogged or almost then chances are the tube is also. Easiest way to clean is it to take the tube off and throw some brake cleen at it. EDIT: might get a new sensor too
Old Apr 8, 2010 | 06:48 AM
Neil64's Avatar
Neil64
MPG
Does a bad or clogged sensor throw a code or set CEL?
Old Apr 8, 2010 | 07:45 AM
Fordbronco69
Infidel
Not sure about the CEL, but mointoring the truck with AE will show it.
Old Apr 25, 2010 | 07:48 PM
kupaa's Avatar
kupaa
Ok i cleaned the ebps and tube and i'm still getting only 12 mpg,checked the breaks for drag and there is none.any more thoughts?
Old Apr 25, 2010 | 10:12 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Fuel pressure? Do you know what you are running while under load?
Old Apr 26, 2010 | 12:41 AM
kupaa's Avatar
kupaa
I only checked it @ idle 55 psi.I just figured that it had enough fuel cause it still has alot of power but I'll check it with a loner hose.
Old Apr 26, 2010 | 01:18 AM
PaysonPSD's Avatar
PaysonPSD
Is that 55 PSI pre filter or post filter. There can be a large PSI drop through the filter.
Bay the way, I will be installing my new injectors tomorrow.
Old Apr 26, 2010 | 02:24 AM
kupaa's Avatar
kupaa
It's taken at the regulator so I'm thinking pre filter.
What size injectors are you installing?
Old Apr 26, 2010 | 08:45 AM
Riffraff Diesel
PREMIUM SPONSOR
If it is at the regulator it would be post filter. Let us know what you find when check it under load.
