Sponsored by: Real Truck
Battery Light(DIM)
Old Apr 7, 2010 | 04:08 PM
mooreman's Avatar
mooreman
Battery Light(DIM)
I have a 99 F250 with a 5.4L and my battery light came on the other day, but its very dim and at idle it flashes alittle. Today i drove the truck to work(did not notice a huge change in the volt gauge) and came out 20 min later to a close to dead battery, so i replaces the battery and the light is still on. The alt. is only 4 years old. Any ideas??????????????????
Old Jun 3, 2010 | 12:53 AM
VANHORN's Avatar
VANHORN
I HAVE A 1999 F350 7.3 WITH ATHE SAME TYPE OF ISSUE. DID YOU FIGURE ANY THING OUT ? I STILL NEED HELP. I WAS HOPING SOMEONE HAD REPLIED TO YOUR POST
Old Jun 3, 2010 | 01:37 AM
twags6's Avatar
twags6
Let the truck sit overnight and cool off. When you go to start it the next day, pop the hood and feel the alternator BEFORE starting it up. If it feels warm, something in the alt is bad (I can't remember what exactly, diodes maybe) and is draining the batteries.
Another thing to check is the plug on top of the alt. Those wires control when the alt turns "on" and a bad connection here can cause it not to charge so well. Make sure the connector is plugged in completely and that none of the wires are loose or the pins in the connector are corroded. If you don't get many replies, post this in the 99-03 7.3L forum thats further down on the main page. We deal with those trucks specifically.
Old Jun 3, 2010 | 02:31 AM
redford's Avatar
redford
FTE Leadership Emeritus
Yes, it is the diodes in the alternator that usually cause this. Despite the fact that the alternator is 4 years old, it probably needs to be replaced.
VANHORN - Welcome to FTE. Could you please not post with your CAPS LOCK on? it makes your text very hard to read.
Old Jun 3, 2010 | 07:11 AM
fishpimp's Avatar
fishpimp
99 f250 v10 going through same thing. i put a new altinator and battery and battery light is still on.
Old Jun 3, 2010 | 05:43 PM
BareBones's Avatar
BareBones
Now that's interesting. A new alternator AND and new battery, and the light is still on....
Yes, I know, the new alternator could be bad, but you know what? I would get someone, like a spouse or girlfriend, to watch the light while the truck is running, and individually remove and reinsert all of the fuses in the fuse box.
If you find one which forces the light off, then you at least know the circuit. Otherwise, yes, you probably have a bad alternator....
And yes, you'll know when you remove the fuse for the computer.....
Old Jun 3, 2010 | 06:26 PM
gearloose1's Avatar
gearloose1
Test / replace Pigtail.
Clean contacts.
Details below.
MO51
Aerostar
13
Oct 24, 2021 08:54 AM
cowmilker08
Feb 20, 2017 09:08 AM
Caldwell F150
1983 - 2012 Ranger & B-Series
Sep 28, 2016 07:22 AM
Manitowoc
Nov 3, 2015 12:18 PM
Damifiknow
Aug 14, 2015 03:50 PM
