2000 Powerstroke Problems?
Old Apr 7, 2010 | 09:10 AM
bad12jr's Avatar
bad12jr
Ok guys. My buddys got a 2000 f250. The truck will run for 2 min and then shut down. It will white smoke the whole time. Has brand new injectors, new gp, HPOP tested good, and new injector harnesses.
Any ideas. Running out of em quick. Hes got it at a shop and im just trying to help him out. Powerstroke is not my best subject. Just got one so im learning.
Thanks guys
Old Apr 7, 2010 | 09:31 AM
rat49f6's Avatar
rat49f6
Might want to try a cps just make sure its from Ford or International
Old Apr 7, 2010 | 09:48 AM
megawatt00's Avatar
megawatt00
Are they injectors brand new? or remans? from where? There are a couple of not so good rebuilders out there. Is the SES light coming on? Have you pulled any codes?
After replacing injectors there is a lot of air in the system and it takes a while to purge it out.
Old Apr 7, 2010 | 10:50 AM
Kajtek1's Avatar
Kajtek1
Sounds like fuel delivery problem for me. Could be air in the lines, could be fuel flow restrictions. Installing pressure gauge on fuel bowl would answer that .
Old Apr 7, 2010 | 08:59 PM
F350-6's Avatar
F350-6
What exactly made him change all those parts out? If it was based on the shops recommendation, tell him to get the truck out of there as they are just throwing parts at it. If he changed all those parts before the problem, then we need to look at what was done before it started.
Old Jun 24, 2010 | 03:42 PM
kipcall's Avatar
kipcall
Post Sounds like egr or transmisssion cooler
Thanks guys
I just replaced my high pressure oil pump and mine did the same thing! Sounds like the egr or transmisssion coler to me I am having to do the same thing on mine! Damn ford 2003 and up are a pain and junk in my opinion!
Old Jun 24, 2010 | 03:57 PM
tdpower's Avatar
tdpower
Welcome to the forum! 7.3's don't have egr stuff. Maybe your are talking about a 6.0 leaker.
To the op definitely check out the fuel pressure.
Old Jun 24, 2010 | 04:25 PM
kipcall's Avatar
kipcall
Yes sir sorry mine is a 6.0 piece of junk! Any idea of why the trans would heat up like it does just out of the blue?
Old Jun 24, 2010 | 04:32 PM
tdpower's Avatar
tdpower
Start a new thread over on the 6.0 forum: 6.0L Power Stroke Diesel - Ford Truck Enthusiasts Forums
You'll get more help over there and we don't want to. Good luck.
Old Jun 24, 2010 | 04:49 PM
kipcall's Avatar
kipcall
Thanks! I think!
7.3 PowerStroke 350
28
Jun 28, 2023 03:05 PM
7.3Powerstroke11
Dec 17, 2015 02:18 PM
Machinart
Jul 16, 2014 12:25 PM
MikeSDK
May 16, 2012 09:44 AM
viperrtblck
Jul 2, 2006 03:52 PM
