rear end
Old Apr 6, 2010 | 04:47 PM
kentruckf100's Avatar
kentruckf100
rear end
i was wondering what would make my rear end make a loud clong noise when i put it in reverse?
Old Apr 6, 2010 | 05:50 PM
dakonthemountain's Avatar
dakonthemountain
It may not be the rear end. It may be your U joint where it meets the differential. Does it only do it in reverse or does it do it again when you put it back in drive?
Dak
Old Apr 6, 2010 | 05:58 PM
mud bros's Avatar
mud bros
^x2 u joints.
with the wheels blocked place the trans in neutral and check for any play between the driveshaft and yokes.
also check for excessive backlash in the rear end yoke you shouldn't be able to turn the yoke more than 1/4 rotation (there will be some normal slop in the spider gears the actual backlash should only be about 7tho of a inch)
Old Apr 6, 2010 | 07:07 PM
kentruckf100
rear end
it is just when i put in reverse.
Old Apr 6, 2010 | 07:44 PM
rodbender's Avatar
rodbender
Somethings loose.
vettex2
Apr 13, 2014 06:19 PM
OKC54f100
24
Oct 11, 2013 07:06 PM
beckman
1997 - 2003 F150
Jul 31, 2012 11:52 AM
rdford17
1978 - 1996 Big Bronco
Dec 8, 2009 12:34 PM
