1978 - 1996 Big Bronco
rear end
Old Dec 7, 2009 | 01:53 PM
rdford17's Avatar
rdford17
rear end
own a 1992 nite bronco with a 302 and a 4EOD tranny. runs great however, the rear end makes a clunking sound when i,m on and off the throttle. the rear end has been rebuilt
Old Dec 7, 2009 | 03:52 PM
Kemicalburns's Avatar
Kemicalburns
start by taking it back to the shop that did the work and tell them. could be a ujoint, loose pinion nut also.
Old Dec 8, 2009 | 02:33 AM
rdford17's Avatar
rdford17
thanks for the quick answer and i will be taking it back
Old Dec 8, 2009 | 10:38 AM
Kemicalburns
i would make sure the rear diff fluid is full before you drive it. do you have a factory limited slip in the back? if so make sure they put friction modifier in there otherwise it will fail. how many miles are on the new gears?
Old Dec 8, 2009 | 12:01 PM
rdford17's Avatar
rdford17
it does have the factory limited slip. i have driven it maybe 400 miles since rebuild
Old Dec 8, 2009 | 12:34 PM
greystreak92's Avatar
greystreak92
Definitely have the shop that did the work look at it then.
jw miller
Jul 6, 2009 10:37 AM
terron78b
Jan 8, 2006 07:54 AM
broncoproblems
Jan 3, 2006 07:32 PM
jambroson
Apr 2, 2004 12:46 PM
Pup
Jul 28, 1999 06:16 PM
