i have a 79 f150 4x4 the signal lights won't blink. Flashers work brake lights work park lights work but the blinkers won't. I have replaced the switch in the column still the same. I have also cleaned every ground front to back what else can i try?
There both very close together around the fuse box, one is just a little higher. Find the one you replaced and turn your 4 way flashers on and remove it to see if the flashers stop. They are both the same type.
