99 F250 Heavy Duty v10
Having problems with my truck and cant figure out what it is? THe truck wont start, windshield wipers wont turn on, the windows wont roll down, the speedometer jumps whenever you try to roll down the windows. It has a new starter as of about 6 months ago. The windshield wipers only come on if you have them turned on and try to roll down a window.
Start by checking that the battery is fully charged and that the battery cables and connections are all clean and secure.
If you don't have a stable and reliable power source, nothing else will work correctly.
Most likely, you have a bad ground. Check the ones on the radiator support and behind both kick panels in the cabin.
StoreBought
04-23-2018 10:28 AM
Mike607
1999 to 2016 Super Duty
02-06-2011 05:48 PM
