Banks Speedbrake
So what does my 2008 F-350 6.4 psd have as far as engine braking? I've never noticed the tow haul helping out like that when I have been towing. Recently I saw a full page ad for Banks Speedbrake directed squarely at Ford 6.0/6.4 owners. I read what I could find and went to Bankspower.com, but I wondered what it cost. In order to find a dealer I had to give Banks contact information, and someone called me the next day. He wanted me to buy the six-gun, IQ, and speedbrake. I told him I did not want a tuner, and, oh by the way, was the speedbrake going to lose me my warranty. It accesses the turbo and the torque converter, so I can see Ford trying to blame it for something. He told me Ford won't know about any of it, and the tuner is not a programmer. And I never did get the name of a local dealer, he told me he'd have to call me back. Who knows, maybe he will.
I don't know about the tuner, but I can see a value to having the engine braking capability on the diesel. Unless I missed something, Ford seems to be the only one of the big three without it. I looked over the forum and have not seen anything on the Banks Speedbrake. Anyone tried it? Former Duramax owners, perhaps? Is this just another way for us to risk losing our powertrain warranty? Or is this a fairly safe add on. Putting in an aftermarket exhaust brake would be a definite no-no according to my dealer, but this doesn't require any exhaust or engine modification.
Rdog1
The IQ is going to be a stand alone (no 6-gun required) very soon. So maybe then the speedbrake could simply just plug into the IQ and a couple of wires going to the turbo. Not sure about that one just yet.
As for local dealers vs dealing with Banks themselves. I would recommend just dealing with Banks as they are actually easy to work with and anyone can do these on their own.
Now for your trans now to downshift in tow/haul. I tap my brakes and it will drop a gear and act as a eng brake. So no real need to for the speedbrake to me.
When in tow haul mode mine does the same as senix explained, just tap the brakes and the truck will downshift and hold that gear the whole way down. For the remainder of the hill I don't need to continuously use the brakes.
Kyle...
I'm trying to resist the temptation to do anything to my truck that will void the warranty. This truck has enough power to easily pull my current toy hauler, and I don't think the mpg improvements provided by a tuner/programmer would pay for the tuner in fuel savings over 4-5 years given my average annual mileage. So a tuner doesn't make sense for me. But I was intrigued to read about the speedbrake. I've read some of Senix's other posts about IQ becoming standalone - something the Banks guy didn't let me know. Sounds like that could be a very useful tool, too. I thought it would be interesting to start up a discussion on the speedbrake since I hadn't seen any posts.
And as far as tapping the brakes goes... It isn't so much as a "tap" more of a apply pressure until the truck downshifts, then release and it will hold that gear for the remainder of the descent. Sometimes it takes a little more to get it to downshift.
Also used Banks exhaust, turbo upgrade and other performance parts and enjoyed the extra HP and torque, until they broke too.
Both worked well for about 5 years until problems began to surface.
Banks is great to deal with during the sales period, and tried to be helpful during the repair work. However, the bottom line for anyone considering these types of aftermarket parts is that it will be (1) difficult to coordinate with your local repair shop and Banks unless you are blessed with a knowledgeable Banks installer in your area, and (2) expensive to ship parts back and forth to California, and purchase replacement parts from Banks. My truck was in a Ford dealership for 6 weeks while I tried to get all the Banks stuff working again, which was finally accomplished at a cost in excess of $3,000.00.
I like my 08' 6.4. The towhaul works fine once you get the hang of it. You won't find any after market parts on this truck until the Ford warranty expires, and then the pollution crap goes in the trash and I will put on whatever parts will best help fuel mileage.
best fuel economy. The overdrive function allows automatic upshifts and
downshifts through gears one through five.
trailer or a heavy load. All transmission gear ranges are available when
using Tow/Haul.
To activate Tow/Haul, press the
button on the end of the gearshift
lever.
The TOW HAUL indicator light will
illuminate in the instrument cluster.
Tow/Haul delays upshifts to reduce frequency of transmission shifting.
Tow/Haul also provides engine braking in all forward gears when the
transmission is in the D (Overdrive) position; this engine braking will
slow the vehicle and assist the driver in controlling the vehicle when
descending a grade. Depending on driving conditions and load
conditions, the transmission may downshift, slow the vehicle and control
the vehicle speed when descending a hill, without the accelerator pedal
being pressed. The amount of downshift braking provided will vary based
upon the amount the brake pedal is depressed.
To deactivate the Tow/Haul feature and return to normal driving mode,
press the button on the end of the gearshift lever. The TOW HAUL light
will no longer be illuminated.
When you shut-off and restart the engine, the transmission will
automatically return to normal D (Overdrive) mode (Tow/Haul OFF).
Do not use the Tow/Haul feature when driving in icy or slippery
conditions as the increased engine braking can cause the rear
wheels to slide and the vehicle to swing around with the possible loss
of vehicle control.
I read that in the owners guide - but my assumption was it refers to the gas engine, which is a lot better braking than with a diesel. If you don't have a diesel you get this owners manual without the diesel supplement, and it applies to the gas engine, which is accurate. So it ignores the obvious difference and begs the question. I couldn't find anything in the diesel supplement about "engine braking". There are, however, warnings (page 6 of the D. supp.) that the PCM will not "..prevent engine overspeeding resulting from downshifting at high vehicle speed or by descending steep grades at too high a vehicle speed for a selected transmission gear..." I take that as a hint to use the brakes as a preventative measure. So the shifting and overdrive stuff I believe. But I ignored references to engine braking in that manual - I'd be more comfortable if it mentioned that it worked for the diesel too, but I doubt it applies to any significant extent to diesels (other than be careful when towing down steep grades to prevent overspeeding). Both Dodge and GM have added active systems to address this issue, but I can't find any reference to Ford having something as well. If it has, I'd love to learn about it and not spend any extra money!
As an example, last summer I decended MT. Washington, NH. This road is very narrow and sharp turns some of it is 12% or more grades. I used the tow/haul mode all the way down and never exceeded 25 mph, thereby saving my brakes. And yes you can really smell it from those in front of you.
You sure that smell was from those in front of you? I do appreciate the benefit of your experience, and I did read the manual, I just didn't believe it. That's why I started this discussion. I've only towed with this truck one season and only had one really steep grade in Conn. on SR 60 (I think). My wife was complaining about the smell too. As I said in my earlier post, I will be paying more attention to how this all works as I gain more experience with it.
