Plugged Cat Converter
Old Apr 4, 2010 | 05:23 PM
thumper477's Avatar
thumper477
My 06 would. barely run or move.No codes either.At a high idle I disconnected the driver side injectors and basicly the left side of the engine showed no difference with them plugged in or not.I suspected a plugged left converter.I hooked up a backpressure tester in the O2 sensor hole before the cat and at anything over idle it pinned the guage.I then unhooked the left pipe from the exhaust manifold and moved it away enough that the left bank could breathe.The truck runs ok with the open exhaust confirming that the left cat is plugged.My truck has 44,000 miles on it.Will Ford cover this under the emission warranty?Will they charge me for testing or diagnosis?In order to get it to the dealer I will have to have it towed or drive it with the open pipe.Any input would be appreciated.Thanks.
Old Apr 4, 2010 | 05:48 PM
85e150's Avatar
85e150
Curse those emissions laws as we must sometimes, this time, it's on your side. Eight years, 80,000 miles for the cat:
http://www.epa.gov/oms/consumer/warr95fs.txt
You can find reference to this warranty in many other spots as well, including the owner's manual.
That's the good news.
Now, make sure you haven't fooled with anything to the point where they can say it's your fault.
AND, keep your fingers crossed that Ford can put their hands on a cat for you. For some reason, '05 Escapes have cat issues and those were badly back ordered for some time, according to posts here. Something about a factory closure or supplier change.
Good luck with it.
BTW, as for taking it off, if you don't have emissions testing, you probably will soon, so try to stick with the OEM set up.
Old Apr 5, 2010 | 06:37 PM
thumper477's Avatar
thumper477
Dropped it off at the Ford store today.I will update after they call me.
Old Apr 7, 2010 | 05:44 PM
thumper477's Avatar
thumper477
Ford dealer called and said they will not replace the cats.They said the cats were done once before with the previous owner of the truck under the emissions warranty and
Ford will not do it again for free.Plus he said the cats were on national backorder(I wonder why!).So I am going to pick up the truck and have some aftermarket cats welded in at my buddy's muffler shop.Then I will have to figure out what on this truck is killing the cats.Stay tuned for further updates.
Old Apr 8, 2010 | 12:51 AM
85e150's Avatar
85e150
Up to you, but I would press them. The warranty is a Federal law, and I don't have a copy of it, but the EPA site says nothing about a "one time" replacement. These cats should still be covered imo.
Ford "policy" can't override a Federal motor vehicle warranty law. Sounds to me like Ford knows they CAN'T get the cats, and is doing anything to get you out of their shop and push the problem back on the owners.
Ford is in a good spot right now in the market. It would be a shame to see this kind of thing undermine their position. More like GM and Toyota BS imo.
Good luck.
2003 kr
1997 - 2003 F150
Jan 23, 2013 07:12 AM
fstbck1970
Dec 23, 2012 09:32 AM
BandtChsr
1978 - 1996 Big Bronco
Dec 13, 2010 08:13 AM
MichiganHunter
2004 - 2008 F150
Mar 9, 2009 07:45 AM
kenneBF250V10
Modular V10 (6.8l)
Sep 27, 2004 09:23 AM
