Modular V10 (6.8l)
True dual exhaust and catalytic converter?
Old 09-23-2004, 08:12 AM
kenneBF250V10's Avatar
kenneBF250V10
kenneBF250V10 is offline
kenneBF250V10 is starting off with a positive reputation.
Here is what I am contemplating. The cat went bad on my '01 V10. I checked with a Ford dealership and found out that a replacement would cost $1300. I don't think so! As a temporary fix I removed the cat and put in a piece of straight pipe. What I want to do and what was also recommended to me by a performance shop is run a hi-flo cat off of each side of the engine and run a true dual exhaust. I plan on getting two Flowmaster 40 Series Delta Flow mufflers and two high flow cats. Any suggestions on hi-flo cats and is anyone running a setup similar to this and should an H-pipe be factored in?
Old 09-23-2004, 10:02 AM
V10KLZZ71S's Avatar
V10KLZZ71S
V10KLZZ71S is offline
V10KLZZ71S is starting off with a positive reputation.
Certainly add an h-pipe.With my duals, for a week i had no h-pipe and could tell something was not right,well I went back and had them put one on there and it was like night and day! Smoothed out the exhaust note and a noticeable increase in low end trq.Check out my two gallerys for a look-see.I personally like magnaflows since they are a straight thru design.Also you need to make sure where you mount the converters as far as heat is concerned.Keep the transmission shielded.
Old 09-23-2004, 10:23 AM
kenneBF250V10
I looked at your gallery and have a couple of questions. Are both tailpipes running out the passenger side and are you running any cats. I was thinking about running both tailpipes in front of passenger rear tire but wasn't sure how it would look. Another reason for wanting to do that is that it would cost a whole lot less because of not using near as much pipe.
Old 09-23-2004, 12:03 PM
V10KLZZ71S's Avatar
V10KLZZ71S
Both out in front of tire, i have a pic of them in one shot in my second gallery.No cats, i think both pipes coming out the side looks good.
Old 09-23-2004, 01:57 PM
kenneBF250V10
Thanks for the info!
Old 09-26-2004, 07:02 PM
1tonJudd
1tonJudd is offline
1tonJudd is starting off with a positive reputation.
Hey V10, how does the V10 run with no cats? Is there any loss in the low end?? thanks, Judd
Old 09-26-2004, 07:32 PM
V10KLZZ71S's Avatar
V10KLZZ71S
NO! I have more.
ps In fact i can lug around with a trailer loaded with 4 wheelers and other stuff @ 1800 rpms with out the trans downshifting.Pulls good below 2000 rpms.At 3000 rpms it really comes alive till about 52-5300.At the lower rpms it has a very deep sound which is what most folks are looking for.
Old 09-27-2004, 04:32 AM
V10man's Avatar
V10man
V10man is offline
V10man is gaining momentum as a positive member of FTE.V10man is gaining momentum as a positive member of FTE.
Don't cats have a longer warranty??
Old 09-27-2004, 07:24 AM
kenneBF250V10
They do (80,000 miles), but the Ford dealer told me that since I have modified the vehicle, it is no longer covered.
Old 09-27-2004, 09:23 AM
kenneBF250V10
NO! I have more.
You are about the only user that I can find that is running a true dual setup. What diameter inlet/outlet muffler are you using and are you using the regular FM 40 series muffler or the Delta flow series?
fairlaniac
1999 to 2016 Super Duty
07-30-2017 07:30 PM
DieselCamper
03-01-2017 01:08 PM
TMI
12-22-2016 10:13 AM
the cleaner
Modular V10 (6.8l)
11-15-2015 09:54 AM
strokin'_tatsch
Exhaust Systems
23
09-16-2010 02:29 PM
Quick Reply: True dual exhaust and catalytic converter?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
