VXCF9 Proof
Old Apr 4, 2010 | 09:01 AM
w_huisman's Avatar
w_huisman
VXCF9 Proof
No SES ever triggered. This happened several more times on my way home from the Missouri River yesterday with my 4klb boat in tow.
Old Apr 4, 2010 | 08:49 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
What am I missing here?
Old Apr 4, 2010 | 08:54 PM
MoyockPowerstroke's Avatar
MoyockPowerstroke
That he's seeing differences of 15*f or more between his EOT/ECT and the VXCF9 strat is supposed to set a CEL or SES light indicating potential oil cooler concerns.
Old Apr 4, 2010 | 08:57 PM
w_huisman's Avatar
w_huisman
The new VXCF9 strategy is rumored to trigger the SES light when EOT exceeds ECT by 15 degrees.
I have the new VXCF9 strategy, and I didn't get a SES light for any of the instances shown in the pictures above.
Old Apr 4, 2010 | 09:07 PM
bismic's Avatar
bismic
The TSB states that it will trigger a CEL.
If the dealership tech did not upgrade to the proper (updated) version of the IDS software, you might not have got the most recent flash.
Old Apr 4, 2010 | 09:11 PM
w_huisman's Avatar
w_huisman
What do you mean "IDS software"? My strat is VXCF9117 according to my sct.
Old Apr 4, 2010 | 09:14 PM
bismic's Avatar
bismic
I really do not know if that is the most recent version or not. It could be I guess. The IDS software is the computer that the dealership has that they use to program your trucks computers.
I will try to look up the TSB tonight or tomorrow.
Old Apr 4, 2010 | 09:19 PM
w_huisman's Avatar
w_huisman
Well, if it wasn't the most recent version at the time I had it installed (early Feb), I wasted $83 at the dealership, which would be frustrating. I hope that's not the case, but I don't know how to tell.
CHEEZIT- have you had any trucks come thru with this strat or older showing a code for the 15 degree diff?
Old Apr 4, 2010 | 09:27 PM
paulkcbulm's Avatar
paulkcbulm
I am also wondering if on my newly bought used truck the VXCF9 is installed. How can I find out what is installed?
Old Apr 4, 2010 | 09:32 PM
MoyockPowerstroke
According to TSB 9-24-3, dated 20 Nov 2009, Action reads:
Reprogram the powertrain control module (PCM)using IDS release 63.13 and higher or 64.01 and higher. The transmission control module (TCM) and fuel injector control module (FICM) , will automatically update if they are not at the latest calibration level. This new calibration is not included in the VCM 2009.11 DVD. Calibration files may also be obtained at Motorcraft.
Specifically:
Oil cooler efficiency monitor - DTC P012F stored and wrench warning lamp illuminated when the oil coolers efficiency drops below a specified threshold for a given speed and vehicle load condition.
Cooling loss protection - Revised engine protection strategy when an engine over-temperature condition is present. Vehicles updated with this service calibration will display higher temperature gauge readings when high EOT conditions or high ECT are encountered and may disable EGR operation to prevent possible EGR cooler damage.
Old Apr 4, 2010 | 09:40 PM
bismic's Avatar
bismic
Thanks Moyock!! The quote that I captured above from your post sounds like the potential is there for us NOT to get the most recent calibration!
I thought that the TSB might also list a strategy code. I was mistaken.
Old Apr 4, 2010 | 09:41 PM
w_huisman's Avatar
w_huisman
That is what I suspected... That there were more triggers that needed to be met, in addition to the 15 degree temp diff, in order to trigger the ses light.
Too bad we don't know the specifics of the "engine loading" parameters.
Old Apr 4, 2010 | 09:44 PM
w_huisman's Avatar
w_huisman
Good catch Mark. They sdefinitely should list specific strategy numbers in those TSBs.
Old Apr 4, 2010 | 09:54 PM
bismic's Avatar
bismic
WADE - The post in the link below states that the most recent flash is VXCF9H7. Could it be that yours really should be "H7" and not "117"?
Choosing a flash - Diesel Forum - TheDieselStop.com
Old Apr 4, 2010 | 09:55 PM
william_04_x's Avatar
william_04_x
I was watching temps today while towing heavy(11K# trailer). I was going up a long grade, with a brutal headwind. I saw EOT as much as 19*> ECT. I wasn't concerned, but I did think about the 15* wrench light programming. My truck is running well and I couldn't imagine the oil cooler being that efficient under heavy loads. On the flats my temps are within 5* of each other. Re-assuring to read that there's more to the wrench light strategy than just temps.
