Torque settings.
Old Apr 3, 2010 | 06:15 PM
mabc926's Avatar
mabc926
Torque settings.
Alright finally got the last of the head bolts in just need some torque settings on....
-head bolts
-rocker arms
-air intake
-exhaust manifold
I've heard so many different torque settings for head bolts 100, 75, 175?......but the rest of the bolts I have no clue what to torque them too.....and I'm using fel-pro head gaskets if that matters....I looked on the box they came in but it had no torque settings on it...anything you guys can tell my will help a lot.
Old Apr 3, 2010 | 07:52 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Which engine are we working on?
What modifications are we working with?
Any parts upgrades?
Old Apr 3, 2010 | 08:03 PM
mabc926's Avatar
mabc926
7.3 only mod is a home made turbo setup no parts upgrade yet.
Old Apr 3, 2010 | 08:05 PM
kenpobuck's Avatar
kenpobuck
The head bolts for starters shoulod be replaced with new. The torque on them goes as follows, 45ft lbs in numbered sequence (that I don't have a pic of sorry). Then to 65 in numbered sequence. Then torque to 75 in line sequence starting with the top left bolt from front of enginegoing to the right then down to the next row back to the left then the bottom row back to th right. Then repeant step 3.
The rocker arms are as follows, turn the engine over by hand till the timing mark is at the 11 o'clock postion, install the rockers and torque to 27ft lbs.
Intake alsohas a numbered sequence that i don't have a pic of but the torque is 24 ft lbs in that sequence then in line sequence at the same torque.
The exhaust is 30 ft lbs for the 83-85 engines and 35 for the 86.
I know that not haveing the picks sucks but I hope this helps some.
Old Apr 3, 2010 | 08:08 PM
kenpobuck's Avatar
kenpobuck
Oops guess I should have asked that first. Some times i can be real dense lol.
Old Apr 3, 2010 | 08:14 PM
mabc926's Avatar
mabc926
I'mma go a little off topic here but...on the rocker arms they have a little T at the end of them...the rocker arms I got off the junk yard 7.3 the T < --- is just like that,,,but on the rocker arms I got with the truck the T is upside down...whats up with that?...and does it matter if the T's are different?....I didn't know if one was stronger or not.
oldtexasdog
Sep 22, 2011 10:09 AM
jcee
2004 - 2008 F150
Mar 24, 2009 07:41 PM
Diesel Reaper
Apr 17, 2008 07:25 AM
John - NNY
Flathead V8 & Flathead 6
Apr 26, 2006 08:55 AM
