Sponsored by: Real Truck
Charging problem
Old Apr 3, 2010 | 01:59 PM
ak49er's Avatar
ak49er
Charging problem
I have a problem on a 03 F250. My charge light is on in the dash. I changed the alt. and still have a light.
I cked the voltage on circuit 904 LG/RD. I have 12 volts key on engine off & 2 volts with the harness pluged in to the alt. I start engine with no change. I jumpered circuit 35 and 904 and the alt. did not start charging
Is my new alt bad? How do I ck. The alt. on engine?
Old Apr 3, 2010 | 02:31 PM
gearloose1's Avatar
gearloose1
What are those circuits?
2 volts? is that a mistake?
See alternator diagnostics link below.
Old Apr 3, 2010 | 05:05 PM
ak49er's Avatar
ak49er
Charging problem
The circuits I tested were to the voltage regulator on the alt.
Yes 2 volts was Correct. The manual says this is normal for Key on engine off voltage. The voltage should come up to 8-9 volts after the eng. starts.
After i changed the alt I cked. the voltage at the regulator. The GN/RD wire or (I) wire had 13 volts. The Book says that should have had 8-9 volts. The OG/LB wire (sensing) had Bat. Voltage (14 Volts). The alt worked fine for a couple days. Is it possable there is a problem with the PCM putting putting to much voltage (13 V) to the regulator and frying the reg.
Also if I put 12 volts to the GN/RD wire (I) on the regulator. will that bypass the trucks wiring and rule out a bad alt. as the problem?
Old Apr 3, 2010 | 05:21 PM
gearloose1's Avatar
gearloose1
Is this a gas or diesel?
Single or dual battery?
Old Apr 3, 2010 | 05:24 PM
ak49er's Avatar
ak49er
gas, single bat.
Old Apr 3, 2010 | 06:01 PM
gearloose1's Avatar
gearloose1
Do an output test by measuring voltage and current from the alternator at, say, 1,800 rpm.
Turning on everything electrical (headlights, AC, fan, etc.) to raise the electrical load.
See what current is coming off the alternator.
If voltage is substantially below 14v, and current is low... then you have an issue with alternator output.
Work backwards, first to field winding power.. if that is OK, then you are down to bad alternator.
Test batteries while you are at it too.
Old Apr 3, 2010 | 07:09 PM
ak49er's Avatar
ak49er
My second new alt. came in and fixed the problem for now. I fear it will be back.
Thanks for your help.
I will post the root cause of the problem if it develops to the point were it can be found.
garydmundy
Nov 25, 2013 09:45 AM
welder1
Feb 24, 2010 04:30 PM
mblayton
Nov 16, 2007 10:30 PM
kawa
25
Sep 3, 2007 08:59 AM
Rusty01
Electrical Systems/Wiring
20
Sep 6, 2005 10:52 PM
