Alt dash light flashing
Old Nov 15, 2007 | 09:54 PM
mblayton's Avatar
mblayton
Finally got my charging problem fixed, thought it was two weeks ago but truck died again. So I checked the voltage with my tester and while the truck was running it would only read 12.3 volts, so I replaced the regulator again with another (#3), plugged everything back together and retested 14.2 volts finally a charge from the alt. but when I went to shut of the ignition I noticed the alt. light on the dash flashing. But the realy weird part was when I put the headlights on the light went out. Anyone have any ideas.
Old Nov 16, 2007 | 08:37 AM
steveh's Avatar
steveh
typically it is a bad diode in the alternator!
Old Nov 16, 2007 | 01:13 PM
Mil1ion's Avatar
Mil1ion
flashing or flickering ?
conditions at time of charging test ?
Idle or 1000 rpm ?
Don't do it at idle.
Old Nov 16, 2007 | 02:01 PM
mblayton's Avatar
mblayton
Idle or 1000 rpm ?
Light was flashing, at idle as well as when driving. I was just out for a ride in it and it did not do it once this trip. Hopefully it has curred itself.
Old Nov 16, 2007 | 02:33 PM
blue68f100's Avatar
blue68f100
Could be a loose connection on the alternator.
Old Nov 16, 2007 | 10:30 PM
Mil1ion's Avatar
Mil1ion
There is a thread in the electrical forum that deals with this problem and the solution to it.
EDIT:
https://www.ford-trucks.com/forums/6...g-problem.html
Handdsaw
Jan 26, 2017 08:25 AM
brobrad
Dec 11, 2016 07:57 AM
mrxf350
Oct 11, 2016 09:17 PM
carbon coupe
Mar 19, 2016 12:39 PM
Jason Lilly
Modular V10 (6.8l)
Jan 28, 2016 02:17 PM
