Coolant seeping through Cap
Old Apr 2, 2010 | 12:51 PM
Dyllan78's Avatar
Dyllan78
2004 6.0 f250
I posted a thread about a hissing sound, kept an eye on it. There is coolant comming out of the cap also. Not much, and i still hear the hissing. I recently did a coolant service to my truck and it seems that the level is over the max line. should i take some out, is the hissing sound related? any info would be great before i try to get it fixed and they try to rape me at the mechanics.
Old Apr 2, 2010 | 12:53 PM
utjer's Avatar
utjer
Yes, remove some coolant. The new full line is the min line. Some guys are running theirs just below the min line. There is lots of talk on here about this.
Old Apr 2, 2010 | 01:12 PM
Dyllan78's Avatar
Dyllan78
thanks a lot
Old Apr 2, 2010 | 01:14 PM
gearloose1's Avatar
gearloose1
Also.. did you get the new updated cap? Verify that cap form a tight seal with the bottle?
Old Apr 2, 2010 | 01:25 PM
w_huisman's Avatar
w_huisman
FYI-
New degas cap pn is 9C3Z-8101-B. $10-$11 at most dealerships.
Old Apr 2, 2010 | 01:28 PM
Dyllan78's Avatar
Dyllan78
Do u guys think that this is also why i hear a hissing noise that comes and goes? Going to get new cap, hope everything else is ok.
Old Apr 2, 2010 | 01:32 PM
w_huisman's Avatar
w_huisman
New cap is the place to start because it's cheap and may be faulty, but...
If the coolant is chocolaty, you probably have a ruptured oil cooler.
If the coolant is clean but really spews out of the cap under load, you probably have leaky head gaskets.
Old Apr 3, 2010 | 11:59 AM
Dyllan78's Avatar
Dyllan78
Is the head gaskets an expensive job, about how much just incase so i know im not getting ripped off. If i dont have a good mechanic should i go to the dealer? Or should i drive futher out about an hour or so where i know of a good mechanic?
Old Apr 3, 2010 | 12:04 PM
02GrayPowerStroke's Avatar
02GrayPowerStroke
I have heard between $3500-5000. Just depends who you are asking.
Old Apr 7, 2010 | 08:35 PM
Jayybird's Avatar
Jayybird
Coolant level ?
Should the coolant level be on the min line when engine is cold?? Cold meaning hasn't run in a day or 2. I am investigating leaking coolant, i had my gaskets replaced, studs installed, and egr delete about 15k miles back. Just installed a coolant filter about 500 miles ago and notice coolant level is low. I suspect (and hope) it is just leaking around one of the hoses. Not sure though, can't find where it would be leaking everything is DRY as a BONE when I look. Any suggestions?
Old Apr 7, 2010 | 08:46 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
No...it should be at the minimum mark when the engine is hot. I run mine a little lower than that.
Old Apr 8, 2010 | 07:40 AM
Jayybird's Avatar
Jayybird
Ok, that makes sense. I had filled mine up to the min level when the engine was cold (I had toped it off when i installed the coolant filter). So frow what your saying I probably overfilled it. If that is the case, maybe some puked out of the cap. Now when the engine is cold the level is about 1/2" below the min line. I'll keep my eye on it, but the last couple days it has stayed there. Do you think i just had too much and a little puked out? I am just trying to pay attention and be cautious, don't want any damn problems with this thing.....especially since we did the gaskest and studs already. Thanks
Old Apr 8, 2010 | 08:09 AM
SteveBricks
FTE Emeritus
More than likely.
Old Apr 8, 2010 | 10:11 AM
69cj's Avatar
69cj
Also, whenever you open the cooling system up, servicing or adding a coolant filter, you can get some air trapped in the system and after a good drive it will clear itself and now you will be low. A good sign of that would be a low degas bottle and no coolant around the cap. With premium gold coolant if it is puking you will see the dried coolant on the degas bottle. It's like a fingerprint. Premium gold is messy when puked.
Old Apr 8, 2010 | 11:58 AM
Jayybird's Avatar
Jayybird
That makes sense, good point. I didn't think about that when i installed the coolant filter. I essentially just trapped a quart of air in the system. The worrying is easing...thanks for the suggestions. I'll look around the degas cap & bottle this evening to see if I can tell if it had puked from there. Thanks
Gental Ben 2
May 9, 2019 11:25 PM
dpurcell
Sep 14, 2011 01:15 AM
polosabre
Sep 8, 2010 08:32 PM
EXMAN123
Jul 30, 2010 04:34 PM
madtom
Dec 14, 2009 07:10 PM
