Check your tach for movement when cranking. No movement replace the CPS. Some movement may still be CPS.
Check to ensure that there are no connection issues at the cps. Check HPOP level and ensure that its a 1/2 or so from the top.
Well, with what Rick and Dan have said, I would open up the fuel bowl and check that, and clean the FPR system.
If the bowl is empty when you open the cover, you'll def know your problem then.
I know CPS does weird things, the ticking part is the part that I don't about.
Next time it dies, stop and pull the HPOP plug and see if the level has dropped in it. It should be about a 1/2 from the top.
Next time its running and you have it hot locate the map sensor electrical connector above the ac unit at the firewall where the hose routes from the turbo boost pressure and un plug the connector. If the truck runs beter then the map snsor is either bad or the small hole at the hose to turbo connection is fouled out or the sensor is fouled out.
One thing to ask does it fire right back up and run like nothing happened afterwards?
I am leaning towards a gap clearance when hot at the CPS. Also do you know your frp pressure at idle?
I would check for codes, mine had codes with no flashing WTS
I forgot to hook the map line back up the last time I took the pass side valve cover off. I was so confused for about a mile and a half. it ran fine, but had no go. haha.
