Fluid Temps
Old Apr 2, 2010 | 08:24 AM
billman13's Avatar
billman13
Fluid Temps
Just wondering what are acceptable temps when towing. my oil went to 200+.... same with trans. egt spikes (hills) stayed under 1250. I babied the 7.3 on the way home till I figure this out. There were times that I was climbing hills droping below the speed limit and I know the 7.3 should/will handle things but I need peace of mind first. So how hot is too hot with oil and trans fluids??
Old Apr 2, 2010 | 09:55 AM
03-6L-X's Avatar
03-6L-X
If you have not already might want to Post this on the 7.3L section.
Make sure you give as much information about any mods you have done too.
Old Apr 2, 2010 | 10:22 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Moved....
Old Apr 2, 2010 | 01:10 PM
Duck Hunter81's Avatar
Duck Hunter81
Tranny temps
I was told with the tranny that you can run it all day under 225 degree. 225-250 is ok for a short while and 250+ means pull over and let it cool.
Not sure about the oil but I would think it would be similiar.
Old Apr 2, 2010 | 05:02 PM
koabob's Avatar
koabob
My EOT gets up to 230 when pulling 5th wheel up hill than goes down to about 220 on flats, I have a stick so no trany temp. (not too much flats here in Ut.)
Old Apr 2, 2010 | 07:59 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Yes, that's correct.
petrokiller
Jul 13, 2014 04:40 PM
Kookadala
Nov 3, 2013 09:26 PM
Peel5050
Aug 10, 2012 08:05 PM
kjnstl
16
Aug 9, 2012 10:40 PM
