What could cause this clunking front end noise over bumps?
Jack up the truck and put it on jack stands (do not do this while its supported by a jack!). Grab hold of the wheel/tire at 3 oclock and 9oclock. Push back and forth and look for play in the linkage. Next do 12 oclock and 6 oclock. Again look for play/looseness in any of the joints/pivot points. Do both sides. This is a start. The noise could be from just about anywhere up there, tie rods, upper/lower control arms, sway bar end links, etc.
Good luck, let us know what you come up with.
Possible Rack
Can you feel anything in the steering wheel while going over bumps at low speeds? If so it may be the steering rack. I guess it would seem unlikely with only 56k but it may be worth a look. Search the forums for steering rack issues and you'll see some info on front end clunking noise. I replaced mine,was a little skeptical as to weather or not it would solve the problem but sure enough it did!
poshardja
1999 to 2016 Super Duty
32
09-30-2018 06:31 PM
Shwan_89HD
19
11-06-2012 08:59 AM
