fuel gauge doesnt work.
Old Apr 1, 2010 | 06:33 PM
300/6 Freak's Avatar
300/6 Freak
just like the title says the fuel gauge doesnt work. is there a fuse for it that could be missing or blown? or will i need to drop the tank?
Old Apr 1, 2010 | 06:57 PM
ctubutis's Avatar
ctubutis
I'm sure there must be a fuse for the gauges in the fuse box but I doubt that's your problem;
to be certain, do your other gauges work?
Most of these problems are caused by worn-out sending units; with the key in ACC or
RUN, disconnect the wire from the sending unit, the gauge should swing all the way to one
direction (I believe EMPTY but not positive). Then, ground that wire to the frame or body,
the gauge should swing fullt in the other direction. If that test passes, then your gauge and
wiring are good and the problem is in your sending unit, most likely the very fine wire has
worn through and maybe unraveled. Some guys have problems with brass floats that fill up
with gas and sink to the bottom but in my experience, that happens less frequently than the
worn-through wire. If you remove the sending unit, remove the triangular cover (held on with
3 bent-over tabs) and look inside....
Old Apr 1, 2010 | 06:58 PM
plumber01's Avatar
plumber01
could be the sending unit went out
Old Apr 1, 2010 | 08:16 PM
Noveske's Avatar
Noveske
Before you buy a new sending unit, drop the tank and manual check the old one. I mean pull it out, and have someone tell you if the gauge changes when you move the lever up and down. Mine turned out to be the little float on the sending unit arm was flooded. I went to the local Ford dealer and they still stock the parts, and they're really cheap. Overall it's an easy job.
Old Apr 1, 2010 | 08:27 PM
plumber01's Avatar
plumber01
definently a smart move..always start with the obvious and cheapest route first.
Old Apr 2, 2010 | 12:12 AM
300/6 Freak
yeha I was tryiong to avoid dropping the tank.
Old Apr 2, 2010 | 12:26 AM
plumber01's Avatar
plumber01
Don't feel to bad, I have to drop two on mine this weekend
Old Apr 2, 2010 | 06:22 PM
300/6 Freak
well if I drop it I will probally just replace the rear one with an oversized tank and jsut not use the front one for now. how would I go about that.
Old Apr 2, 2010 | 07:33 PM
plumber01's Avatar
plumber01
Dropping the tank is not as bad as it sounds unless it's full of gas. But going to a bigger tank (I AM NO EXPERT, JUST SHOOTING HERE) If it is deeper then you will have to get the bars to hold it to the frame, and if it is longer make sure it will not impeede with anything else you may have to do some drilling on the frame to change the support holes.
Old Apr 2, 2010 | 09:26 PM
300/6 Freak
I would be adding this tank LMC Truck Parts - Page 117 at the top
Old Apr 2, 2010 | 09:41 PM
plumber01's Avatar
plumber01
looks like it comes with everything needed except where to remount the spare tire
Old Apr 2, 2010 | 09:42 PM
plumber01's Avatar
plumber01
May want to dtart a new post on WHERE TO RELOCATE SPARE TIRE and see if anyone else has done it before that might have some suggestions
Old Apr 2, 2010 | 09:45 PM
ctubutis's Avatar
ctubutis
Sounds cool; given the gas mileage of these things, that would be nice! Except for the $100 bill
at the gas station to fill it up....
Old Apr 2, 2010 | 09:59 PM
plumber01's Avatar
plumber01
Both of my guages aren't working. Probably because my grand father stuck a garden hose down the tanks to ciphon gas out to keep from going to the store to fill up the lawn mower and twisted it all up to get it in there. GOD love the DO-IT-YOURSELFERS
Old Apr 3, 2010 | 08:07 PM
BurninValves's Avatar
BurninValves
Noveske, sweet truck.
