Click, Click...sizzle...
Old Apr 1, 2010 | 05:05 PM
CalebJns's Avatar
CalebJns
That is the main problem...there are zero vacuum lines hooked up...thus I need a diagram, so I can get everything hooked up properly.
Old Apr 1, 2010 | 08:28 PM
75F350's Avatar
75F350
At the very least you have the vacuum modulator, power brake booster and vacuum advance hooked up right?
At least they are blocked off? If no, you have a terrible vacuum leak at the vacuum tree or at the base of the carb.
Old Apr 1, 2010 | 08:51 PM
CalebJns's Avatar
CalebJns
The truck does not have the power brake booster...the van did however. So that tube will have to be plugged...as far as the Modulator, and advance hooked up...
Old Apr 1, 2010 | 08:57 PM
75F350's Avatar
75F350
For now, just make sure that you have all of the ports on the intake and carb plugged so you can tune the thing. A vacuum leak will be a tuning problem.
Old Apr 1, 2010 | 09:53 PM
CalebJns's Avatar
CalebJns
I went online and found me a Chilton Manual for the van model, it is supposed to be here Saturday...so I am busy tomorrow, going to get headers for it...Hedman Shorts...so I wont be able to fiddle with it much until Saturday anyway...but I do have it all covered, since I still have the hood off and all...but I started another thread asking about the transmission..."Neutral Safety Switch"...any advise on that issue?
deezdrama
Aug 21, 2016 02:33 PM
Redneckmorton
Aug 18, 2016 06:24 AM
Dank Hill
17
Nov 3, 2015 05:12 AM
TKegs763
Aug 17, 2013 09:23 AM
akfcc350
Dec 4, 2005 05:46 PM
