99' expedition Keypad
Old Apr 15, 2002 | 05:25 PM
charlesvalentine's Avatar
charlesvalentine
Old Apr 15, 2002 | 11:25 PM
bronchitis's Avatar
bronchitis
Key pad takes about 30 times to unlock. I am guessing it must be worn out. I use it exclusivly when it worked better.
Old Apr 16, 2002 | 11:25 AM
Boxter's Avatar
Boxter
When you got the truck, did you get 2 keypads? If so, try using the other keypad. If it works, then the problem is not with the receiver, but the keypad.
Now, if the other keypad works, next easiest thing to look at is the batteries. Take the battery out of the one that works and put it in the one that does not work. Does the keypad work now? Does the problem start on the other keypad? If so, battery issue.
Now, if the batteries have nothing to do with the problem, then it may be possible that you have worn out the button (as you stated). You can get replacement keypads off ebay for pretty cheap.
Boxter
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
Mar 9, 2016 12:40 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
Feb 20, 2014 06:51 PM
