Code scanner
Old Mar 31, 2010 | 08:48 PM
teamlx88's Avatar
teamlx88
Code scanner
Which code scanner will enable me to service bleed the abs unit on my 98 Expy?
Old Apr 1, 2010 | 08:03 AM
c_hohensee's Avatar
c_hohensee
The only one I know of is the NGS scan tool. My OTC ABS reader tool will not not do it, it just gives instructions on how to do it manually.
Old Apr 1, 2010 | 01:48 PM
teamlx88's Avatar
teamlx88
Do you know where I can get one?
Old Apr 1, 2010 | 06:42 PM
c_hohensee's Avatar
c_hohensee
The best place to find them I have found is on Ebay. They are what the dealers used for diagnostics. They are not cheap even used. Although if you get the correct software you can do absolutely everything that con be done with a scanner on a Ford with them.
