Up date on '89 I6 with two timing marks!
Old Jan 26, 2003 | 05:47 PM
Chas1234's Avatar
Chas1234
Well my friend Jared and I looked at the crank damper and found no evidence of another mark .............So in the spring when I replace the cam and crank gears (steel ones) I will clean the damper apply new black paint and add a nice white mark in the correct spot (unless I find it before then) and then make a new mark on the timing cover and so on the damper . Also I would like to take this time and thank everyone who helped out !
thanks again Jon
Old Jan 27, 2003 | 11:20 AM
Ford_Six's Avatar
Ford_Six
Yeah, it's kinda wierd, there is just the notch for the crank position sensor hole, and no v-notch.
Old Jan 27, 2003 | 06:38 PM
stractor's Avatar
stractor
The mark you are looking for is just a scribed line, like some one took an ice pick and made a line on the damper. If the damper is dirty you won't see it. You have to climb under and clean the damper with a brush or sandpaper. At that time you should also see the timing plate bolted to the timing cover.
stractor
Old Jan 27, 2003 | 08:29 PM
Chas1234's Avatar
Chas1234
It is cold outside so messing aroud with the engine is not my idea of fun ...perhaps when its warmer out
Jon
Old Jan 28, 2003 | 01:44 PM
Ford_Six's Avatar
Ford_Six
The timing plate has been found- that is also where the sensore mounts for factory diagnosis. I know that much. I got under there, and looked carefully, and felt the whole perimeter of the damper, and the wasn't anything. I don't mind the cold so much, lol, I am really built for it. But maybe when it gets a little warmer.
