I plan on ordering 4.30 gears and having a local shop install them. I have a Dana 50 up front and a 10.5 rear. Are these the correct parts I need for the gear swap? Any help would be great.
MASTER KIT DANA 50
Part Number: G/235-2054
G2 Axle and Gear Dana 50 Master Installation Kit
Timken Inner Pinion Bearing And Race
Timken Outer Pinion Bearing And Race
Timken Carrier Bearings And Races
Pinion Seal
Pinion Nut
Ring Gear Bolts
Thread Locking Compound
Complete Shim Kit
Gear Marking Compound
Sealer
MASTER KIT FORD 10.5"
Part Number: G/235-2046A
G2 Axle and Gear Ford 10.50in. Master Installation Kit
Pinion Seal
Pinion Nut
Crush Sleeve
Ring Gear Bolts
Complete Shim Kit
Sealer
G-2 Performance Ring and Pinion Set
Part Number: G/22-2046-430L
Ford 10.25in. Long 4.30 G-2 Ring And Pinion Set
Limited Lifetime Warranty
Computer Heat Treated 8620 Steel
Manufactured To O.E. Specs
Double Shot Peened
Double Lapped
Will Fit Ford 10.5 When used With 35-2046 Master Kit
Part Number: G/22-2034-430RX
Dana 60 Reverse Thick 4.30 G-2 Ring And Pinion Set
Double Shot Peened
Double Lapped
For Use With 4.10 And Down Carrier
Part Number: G/22-2034-430RX Dana 60 Reverse Thick 4.30 G-2 Ring And Pinion Set
Double Shot Peened
Double Lapped
You have a 50 up front right??? I don't think the dana 60 gear will work.
Carrier bolt count and size is different. 10 vs 12. 7/16'' vs 1/2''. Look at the specs for each in the links I posted. They are different. Precision Gear does offer a 4.30 in a Dana 50.
