electrical problem
Old Mar 31, 2010 | 06:34 PM
97powersmoke's Avatar
97powersmoke
electrical problem
For the past couple nights, when i start the truck and turn the headlights on, the right turn signal indicator on the dash and my high beam indicator illuminate very dimly. i turned on the turn signal and the indicator didn't blink but when i got out of the truck and looked at it up front my headlight and the running lights were very dim. the turn signal and the curved light above it (next to the headlight) were alternatley blinking but very dimly. i got back in my truck and as soon as i started to drive away it became normal. it's done this a few times so far this week. any ideas? bad ground maybe?
Old Mar 31, 2010 | 07:19 PM
Hussler's Avatar
Hussler
Try pushing the emergency flasher button on/off a couple times.
Old Mar 31, 2010 | 07:38 PM
97powersmoke
aight i can try that but what would that do?
Old Mar 31, 2010 | 08:23 PM
Hussler's Avatar
Hussler
Might fix the problem.
Old Mar 31, 2010 | 09:08 PM
paddler's Avatar
paddler
Only just after starting?
Like the glow plugs are still on, and the volt gage is still showing way low? If so, that's probably normal.
I don't know for sure, but it seems like that at idle, with glow plugs on, the alternator isn't pushing much if any voltage. This might be an alternator longevity feature because the alternator can't push enough current to feed glow plugs & everything else at nominal voltage at idle RPM.
Low voltage... basically batteries under heavy load of glow plugs... will dim the lights and really slow down the flasher controller, and maybe not let it operate at all. Basically what you see with really drained batteries. And if your batteries are weak, they'll be supplying even less voltage until the plugs cycle off and alternator starts pushing nominal voltage.
Try a cold start, when glow plugs stay on for a while. Let idle until volt gage comes up to normal, then see if lights behave normally.
Old Mar 31, 2010 | 09:29 PM
97250hd-earl's Avatar
97250hd-earl
it could be the flasher relays in the fuse panel in dash, one in front of the panel and one on the back side of the panel.
Old Mar 31, 2010 | 09:49 PM
97powersmoke
no your right that is normal but even after the volt gauge goes up the left headlight is bright as normal but the right side is dim.
but the alternating between turn signal bulb and running light? and i only know of one flasher relay in the fuse box inside the cab. i have to pull that one out and put it back when the turn signal doesnt flash just comes on.
Old Mar 31, 2010 | 10:17 PM
97250hd-earl
look on the back side right behind it
Old Mar 31, 2010 | 10:54 PM
97powersmoke
on the back side of the fuse panel? it looks like the round relay thats on the front? aight i'll try it in a min when i get outta work.
Old Apr 1, 2010 | 06:35 AM
97250hd-earl
yes, it may be for trailer tow suport.
