2004 6.0 Whistleing
Old Mar 31, 2010 | 08:48 AM
GoldnTA's Avatar
GoldnTA
2004 6.0 Whistleing
I have a 2004 F350 w/ 83,000 mi. When I let off the throttle when the engine is warm, I am getting a whistle noise that i believe is cooming from the Resivoir cap. Also I have a little white residue around the cap. This winter I had the coolant flushed and they over filled it and it has stayed consistant at about a 1/2" below Min line. Does any one belive that the heads may be going, or should I doo a EGR delete or an Elite Diesel Blocker plate? Thanks for any help!
Old Mar 31, 2010 | 09:04 AM
Headviking's Avatar
Headviking
I had the same sound as you in December. Turned out to be th HG. I had the dealer replace it with ARP's. Now it run great with no puking around the degas bottle and to wistling sound. Have the HG checked
Old Mar 31, 2010 | 09:09 AM
GoldnTA's Avatar
GoldnTA
Did you or have you done an EGR Delete or blocker plate?
Old Mar 31, 2010 | 06:10 PM
flyin200's Avatar
flyin200
Mine did that and i bought the updated coolant cap and went away.
Old Mar 31, 2010 | 09:29 PM
brob1969's Avatar
brob1969
try the degas bottle cap first; an $11 fix if this is your issue
Old Apr 3, 2010 | 08:45 PM
GoldnTA's Avatar
GoldnTA
I checked my degas cap and it is already new. The only time I hear the whistle sound is when the engine is warn and I let off the throttle all the way or after it switches gears and the rpm's drop fast.
Old Apr 3, 2010 | 08:53 PM
cartmanea's Avatar
cartmanea
Could also be a cracked intercooler boot or exhaust leak.
Old Apr 3, 2010 | 09:04 PM
liv's Avatar
liv
Do you know what a turbo fart sounds like? It could be that after you described when it occurs. Anything else will be pretty consistent. Guess it could be a cracked intercooler boot/hose if it was really small. It will get more consistent with time though.
Turbo farts are perfectly healthy btw.
Old Apr 3, 2010 | 09:06 PM
cartmanea's Avatar
cartmanea
Turbo farts don't sound like a whistle, unless he's describing it as a whistle incorrectly.
Old Apr 3, 2010 | 09:15 PM
liv's Avatar
liv
Yea that's why I was asking if he knew what it sounded like. Just doesn't seem likely that he wouldn't hear the noise at high boost, only when he lets off the the throttle.
Old Apr 3, 2010 | 09:21 PM
GoldnTA's Avatar
GoldnTA
I gues it would be a whistle, but mor like a hum noise after i let off the throttle.
Old Apr 3, 2010 | 09:22 PM
GoldnTA's Avatar
GoldnTA
The noise is short and i hear it between 2500 and 1200 rpms
Old Apr 3, 2010 | 09:26 PM
cartmanea's Avatar
cartmanea
A turbo fart sounds like rushing air, it makes a sound like "whoosh whoosh whoosh". Usually does it quickly a few times when you let off the throttle and high boost levels.
liv's Avatar
liv
YouTube - 6.0L Powerstroke SCT Tuned "Turbo Fart"
sound like that?
Old Apr 3, 2010 | 09:31 PM
GoldnTA's Avatar
GoldnTA
It sounded like the nois at the end of the video, the last few seconds when he got back on the throttle.
