5.0 Help
Old Mar 30, 2010 | 09:29 PM
lilrams09's Avatar
lilrams09
5.0 Help
Hi guys i was wondering what i could do to make my 5.0 pull better and have a little more power. it's a 96 half ton it has duals with 1 cat removed. any thoughts would be great and if any of you guys can recomend a chip that would be nice
Old Mar 30, 2010 | 09:37 PM
Conanski's Avatar
Conanski
Pull as in loads or accelerate? What size tire are on it and what is the axle ratio?
Old Mar 30, 2010 | 10:55 PM
FlyCool5.0's Avatar
FlyCool5.0
Hands Down Best Mods On My 1995 5.0 Are The MSD 6A Box & The Full K&N Intake With Tube. Shorty Headers Didnt Impress Me & Constantly Had To Be Retightened. I Have The Jet Chip For Our Trucks In Mine. Honestly Cant Say I Noticed Anything On The Butt Dyno. I Have 3:31 Gears & 154,000 & tryed nearly every mod (besides internal engine rebuild, & Re-Gearing) & Those Two Stood Out As Noticable. Hope That Helps?
Old Mar 31, 2010 | 04:55 AM
lew52's Avatar
lew52
There are alot of things you can do to the 5.0 without tearing into the motor . A few things are , long tube headers with a good free flowing exhaust , advance the timing a few degress , 1.7 ratio rocker arms , underdrive pulleys , gearing on the 5.0 is important , whats your gear ratio & tire size....Lew
Old Mar 31, 2010 | 05:12 AM
TexasGuy001's Avatar
TexasGuy001
The full KN intake is a waste of $. I had it and my truck ran worse and got worse fuel economy. Also the quality of it is lousy. It doesn't seal up at the throttle body. My friend's was this way as well.
Keep the stock air box and get the I6/460 tube. Also, just run a good OE style air filter.
Don't waste your money on TB spacers, or chips either.
A good free flowing exhuast will help some.
I will also say that gearing on the 5.0 is important. Mine came with 3.08 and I upgraded to 3.55 LS after I got my 31 10.50s, it sucked with 31s and 3.08 gears. I really think that 3.55 is a good gear for stock sized tires, but that 4.10 would be nice to have with the 31s I have now.
Old Mar 31, 2010 | 10:12 AM
Conanski's Avatar
Conanski
Yes.. if the truck has anything other than the stock sized tires it needs more than 3.55 gears.
Old Mar 31, 2010 | 04:09 PM
lilrams09's Avatar
lilrams09
i have 285/75/16 's on mine w/ 16 " wheels wich hurts it but i have an exhaust no haders. i hav eliminated 1 cat but not both. also i'm not for sure on my axles will the tag inside the door tell you or not? And i've been wodering about he MSD kits i'll have to try them and see what it does.
Thanks
Old Mar 31, 2010 | 04:14 PM
darthice's Avatar
darthice
yeah you need bigger gears in your truck to run those tires those tires are about 31 inches tall (correct me if i am wrong )
Old Mar 31, 2010 | 04:34 PM
Conanski's Avatar
Conanski
You better believe it, nothing sucks the life out of a 5.0 like big tires. Compare those to the stock 235/75-15's with this tool.. Tire Size Calculator - tire & wheel plus sizing
It says they're over 12% bigger with a 33" overall diameter, that means you need 4.10 gears just to get back to the stock final drive ratio. This is the first thing you need to do, nothing else will make as big a difference as the appropriate gearing.
