Rear End compatibility question
Old Mar 30, 2010 | 09:11 PM
bman1080's Avatar
bman1080
I have a 1953 F100 with 215 engine. I am putting in a 1986 302 and AOD. Should I change the rearend? Will the rearend from the 86 e150 van work?
Thanks
Billy
Old Mar 30, 2010 | 09:25 PM
GreatNorthWoods's Avatar
GreatNorthWoods
Thanks
Billy
If your original rear is in good shape then I see no reason why you can't use it. The AOD will work nice with a low geared rear end. Most van rear ends are way too wide. You want something in the 61 inch range. I don't know what the van is but it's probably a lot wider than 61 inches...
Old Mar 30, 2010 | 10:43 PM
bman1080's Avatar
bman1080
Where do I measure to see? Is the 61 inches from backing plate to backing plate? or Outside to outside?
Thanks and sorry I am new to this. I have been a member for several years but just getting started with my work on the truck again.
Old Mar 30, 2010 | 11:25 PM
52 Merc's Avatar
52 Merc
In the past, people have changed the rear ends not because they were weak or troulesome, but because they didn't want to be turning such high rpm's on the highway, since the stock rears had a fairly low gear ratio, like 3.92:1, and swapping rears was the easiest way to get something more reasonable, on the lines of 3.00:1. With newer cars donating their drivetrains with overdrive automatic transmissions, like yours, it isn't so much of a concern, as shifting into overdrive does that magic for you. Personally, if I was doing your project, I would leave the rear end alone and see how it works, as is. I'm betting you'll like it just fine. It'll give you good acceleration from a stop, and allow you to cruise at a reasonable engine speed, while going 70 on the freeway. The best of both worlds.
Old Mar 31, 2010 | 05:01 AM
norvillebob's Avatar
norvillebob
well stated
Old Mar 31, 2010 | 07:35 AM
bman1080's Avatar
bman1080
Thanks for the advice. I just didnt want to tear anything up. This makes the work much easier now that no rear swap is needed!!
Old Mar 31, 2010 | 09:01 AM
GreatNorthWoods
That's what I was thinkin' but he said it!
Measure the rear end from wheel-mounting-surface to wheel-mounting-surface (drum to drum) or if you have standard offset wheels on it from the center of one tire tread to the center of the other.
billywr01
1997 - 2003 F150
Mar 20, 2005 12:41 AM
dcat14
1997 - 2003 F150
Nov 6, 2003 12:10 AM
Billy Bronco
1978 - 1996 Big Bronco
May 23, 2003 12:49 AM
mikemc
16
Apr 21, 2003 01:20 AM
Billy Bronco
Apr 16, 2003 01:24 AM
