Fluid caught fire
Old Mar 30, 2010 | 06:33 PM
Papa John's Avatar
Papa John
8th Gear
Fluid caught fire
HELP!
My 2000 Ford Excursion caught fire just to the right of the tranny bell housing on the Y exhaust pipe where the two sides come together.
I came through some sand and just a little mud in 2WD, started to bog, put her in 4WL and tried to pull forward, forgot to lock in the hubs, locked in the hubs, she was still in 4WL and had to back a few times before pulling out. As soon as I got out, there was fire the size of a basketball on the Y exhaust pipe and fluid on the bell housing of the tranny. Threw a bunch of sand on the fire to put it out. It was then too dirty to tell what type of fluid it was, but I think it was tranny fluid because it was dripping off the bell housing.
After unlocking the hubs and putting her in 2WD, I drove it home 30 miles on the hard top and checked it many times on the way. Had no leaks in a couple of days with very light driving. What in the heck caused it to leak and catch on fire?
Old Mar 30, 2010 | 06:43 PM
Skip1970's Avatar
Skip1970
i knwo my old ford with the c6 automatic trans, when it would overheat it would puke fluid out the front seal, maybe this is what happened to yours.. i cured it by adding a 2nd trans cooler.. and then it never overheated offroad.
Old Mar 30, 2010 | 07:34 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
YIKES!
Sounds like you need a 6.0 trans cooler....its way bigger than the stock V10 or 7.3 and really keeps things cool...
Old Mar 30, 2010 | 11:37 PM
Papa John's Avatar
Papa John
8th Gear
Sounds like you boys are on to something. I'll look into getting an additional cooler.
Odd thing is that I've had that sucker a heck of a lot hotter than that day under much heavier loads with no spitting fluid and no fires. Even though fluid still looks good, I'll probably look at a fluid flush and filter replacement as well.
I sure didn't know trans fluid would ignite on the manifold, but it sure as heck does.
Thanks for the suggestions fellows.
Papa John
Old Mar 31, 2010 | 12:54 AM
Encho's Avatar
Encho
The Southernmost Mod
I'm pretty sure it was tranny fluid... It is very flamable, well, i hope no harm was done, as everyone else said, get the cooler.
Old Mar 31, 2010 | 06:25 AM
tdappleman's Avatar
tdappleman
If you had the transmission hot and then the truck was bouncing through an area that is enough to splash some fluid.
Old Mar 31, 2010 | 10:19 AM
Toreador_Diesel
The 6.0 trans cooler is not an additional cooler, its THE cooler...
It's bigger than the 7.3 and V10 trans cooler put together and the best part is that it's a direct bolt in. The only difference is the lines, the ones on the Torqshift are slightly bigger than the lines on the 4R100, so you'll have to re-work some of the plumbing. I did it on mine and even in the hot Texas heat, my trans never really gets hotter than 150* at most, on average it's about 130*.
Talk to partsguyed, he'll get you squared away...
Old Mar 31, 2010 | 02:24 PM
Skip1970's Avatar
Skip1970
how much are the 6.0 coolers?
Old Apr 2, 2010 | 08:06 AM
Papa John's Avatar
Papa John
8th Gear
You boys been a lot of help. I will upgrade the cooler.
Thank you all,
Papa John
Old Apr 2, 2010 | 08:27 AM
katiesdad7's Avatar
katiesdad7
Originally Posted by Toreador_Diesel
YIKES!
Finally something good about the 6.0. :-)
Old Apr 2, 2010 | 10:11 AM
Toreador_Diesel
I think I paid between $220 and $250, but when my trans temps rarely exceed 140* it's worth it...
Old Apr 2, 2010 | 12:36 PM
cbradford's Avatar
cbradford
Ed lists for $209.08, check here:
www.partsguyed.com
