02 with k&N
03-30-2010, 12:48 PM
on
02 with k&N
Is there a filter that I can just install thats worthy and leave the K&N duct work?
Newbie Steve
03-30-2010, 02:16 PM
on
possibly the 6637, is the k&n filter conneciton end 4"?
03-30-2010, 04:03 PM
on
I stuck a 6637 over the K&N tube and clamped it down, works fine.
03-30-2010, 04:11 PM
FWIW, I think it is just the drop in K & N filter that sucks...no pun intended. But you can't go wrong with a 6637.
03-30-2010, 05:11 PM
on
So is the full K&N system ok and its just the drop in thats NG?
03-30-2010, 05:20 PM
Quote:
Originally Posted by
superglide04
I believe so, the drop in doesn't fit the stock box well and particles make its way around the seal and dust the turbo.
03-30-2010, 07:16 PM
no if i remember currently the drop is is better then the system.... BUT either way i would stay away from k&n
03-31-2010, 01:46 PM
on
I had good luck with the FIPK K&N filter (replaces whole stock setup). They work if they are maintained properly. I would check the inside of the intake tube often and never could leave a mark. I just got lazy and decided to use the 6637 and a cover.
03-31-2010, 01:55 PM
The 6637 flows better then the K&N
