1978 - 1996 Big Bronco
MAF Sensor
Old Mar 30, 2010 | 12:19 PM
TxFireFghter's Avatar
TxFireFghter
MAF Sensor
Hi, first time posting here as you can see.
Have a question about the MAF sensor. Do I have one? 1995 Bronco 351.
Trying to install a K&N Cold air and noticed that I could choose form 2 of them. With MAF and Without MAF.
Wondering where it is located if I even have one.
Thanks!
Old Mar 30, 2010 | 12:30 PM
Kemicalburns's Avatar
Kemicalburns
probably not but you might be one of the very few lucky ones. only CA broncos/F150s running that engine combo for that year had mass air due to smog regs.
easiest way to tell is there would be a sensor mounted to the air box.
if you have 2 individual tubes running from the throttle body to the air box then you have speed density NOT mass air.
Ford Fuel Injection has great efi related info. read up.
Old Mar 30, 2010 | 12:31 PM
Conanski's Avatar
Conanski
Oiled K&N filters are not recommended as they can contaminate the MAF sensor, and any open air filter will draw in hot air from the engine bay instead of the relatively cold outside air the stock system provides. These open filters can also disrupt airflow through the MAF sensor and result in loss of milage and worse performance. In general a dry drop in filter is the better option, and if you feel you need some extra performance from your intake system you can swap in an intake snorkle from an I6 or 460 truck, that's the part that goes from the rad support to the bottom of the airbox. For some reason trucks with thse motors got a different snorkle that is a little better design.
Old Mar 30, 2010 | 12:38 PM
TxFireFghter
Kemical, thanks! I do have two tubes running from throttle to air bax. nothing is on them.
Conan, ive never heard of that... thanks, now i am going to go investigate that.
Old Mar 30, 2010 | 05:14 PM
greystreak92's Avatar
greystreak92
Yes, oil impregnated air filters damage MAF sensors due to the atomization of the oil in the air as it is carried through the intake plumbing. MAF sensors utilize a heating element wire to determine air flow.
If you think about what happens if you blow air down into your toaster while its on you realize that the heating element wires will darken (cool off) when you do. The MAF sensor uses this effect to determine how much air is flowing into the engine. To maintain a given temperature the element wire needs "x" amount of voltage to maintain that temperature. As air flows across the element wire it cools. The computer then increases the voltage so as to maintain the correct temperature. The amount of voltage required to maintain the proper temperature gives the computer a reference point to determine how much air is flowing into the engine.
If you then start getting tiny oil drops on the MAF sensor wire (because lets face it air passing through an oil-impregnated filter is going to carry some of it away), the wire is going to "bake" the oil onto itself and cause the efficiency of the sensor to diminish and prematurely fail.
Old Mar 30, 2010 | 05:15 PM
greystreak92
duplicate post... (~!@#$%^&*) computers!
Old Mar 30, 2010 | 08:00 PM
TxFireFghter
thanks
nice to know how a maf sensor works. went and looked and i dont have one. so thats a good thing.
i ended up not going with a CIA, but rather just a drop in K&N. did that to my 90 bronco and it helped.
Old Mar 30, 2010 | 08:11 PM
b4hntn's Avatar
b4hntn
I have an air intake tube for sale like Conanski mentioned. PM me if interested.
Old Apr 1, 2010 | 02:44 AM
TexasGuy001's Avatar
TexasGuy001
I agree completely. I had the FIPK on my truck that has mass air and it was worthless. My truck ran worse and got worse fuel economy with it so I got rid of it. Also, it did not seal up at the throttle body very well either. In my opinion KN is junk. I have had the drop in filters and they do nothing. Also KN does not flow as well as people think it does as soon as it starts to get dirty.
I'm running the stock air box and filter with the I6/460 tube. It works great.
BWD444
Electrical Systems/Wiring
Dec 30, 2016 07:52 PM
grandpaj
Air Intakes, Air Filters & Ram Air
Nov 21, 2016 09:38 AM
asavage
Aerostar
23
Nov 29, 2012 11:44 AM
slong
1983 - 2012 Ranger & B-Series
Aug 12, 2011 01:22 PM
AndeyHall
Jul 6, 2011 09:32 AM
