Need help, ex 7.3psd wont start?
I hope before cps change that it throw some interesting trouble code after change and clearing codes, but no, just couple glow plug issue...
I most research tomorrow more about car, maybe its not big issue but finding that is the biggest work.. because trouble codes doesnt tell anything serious
remove the cap on the hi pressure oil pump and see if there is oil in there, if there is no oil then your pump could be bad or the little plug at the bottom could have fallen out and it drains out. My would just stall and restart but was getting worse, new pump and IPR valve she was back in business. Good luck.
Today i check the hpop reservoir cap and it was full, less than 1/2" of top. And i also disconnect injection pressure sensor plug and it was all way oil. I clean both connectors and put it back, but wont start, also tried start while plug was disconnected but wont start. Also clean IPR connector, it was clean, and no any signs about leaking HPOP.
And i also connected edge evolution to stream data and here is it what it throw: just thinking, does the "line pressure" (5psi) mean hpop pressure what goes to injectors or tranny line/master pressure?
Maybe i try next order new injection pressure sensor and IPR
Sounds just same, like when Injection pressure sensor was connected, no smoke..
So it has been that the "line pressure" reading is of tranny... must get checked the high pressure oil line pressure... but if there is any issue, could IPR valve go so bad, that it doesnt get pressure up at all?
I just remember that the SES light is on, when i turn key on and also while starting, which issues could cause SES light? i still get just 2,4,6 glow plug trouble codes, no anything else... if there where some pcm or some else bigger issue would it throw some trouble code?
I hope of course that the issue go away after IPR and ICP is changed but can not know until those parts comes...
these i have checked:
-no smoke
-hpop reservois was full even after long start.
-CPS is new grey one, nothing change compared the old one (black, original stock?) tach moves +100rpm while starting
-Clean ICP and IPR connectors, icp has oil over it.. waiting for new. Also tried start when ICP is unplugged -> no change..
-Fuel pump is working
-Fuel filter is new
-Engine oil look good same color in the engine oil pan and hpop reservoir
-batteries cranks engine well
and again, thank you all in advance!
-no smoke
-Fuel filter is new
-no smoke
-Fuel filter is new
-no smoke
-Fuel filter is new
It is the designer's way of letting you know that the system, bulb, etc is working normally. It is designed to come on for a few seconds, then go out right after the engine gets started and is idling.
Going now to review this thread to see if some detail has been missed.
#29
Do i remember wrong or did i read somewhere, that if the cps is bad HPOP/IPR doesnt let create the 500psi to injectors? some safe think?
#30
No egde can not do that, but i just ordered mechanical gauge kit so when that comes i can check that, if the hpop pressure increase to ~500psi while starting, that tells lot, if the pressure is ok and still wont start would the IDM/PCM go bad without throwing any trouble codes?
If I had to guess I would think that if the IDM has failed it would throw a code.
But if you have a P1316 IDM code, you need to check the wiring for the injectors under the valve cover gaskets. I can tell you from personal experience ( I accidentally left one of the injectors unplugged one time ) that if it is disconnected anywhere, it will throw that code.
This is only if you are trying to diagnose a P1316.
You have to check all the wiring first before you call it a bad IDM.
It doesn't hurt to check the IDM, it is mounted inside the left front fenderwell and sometimes they succumb to water contamination.
