slight vibration
Old Mar 30, 2010 | 09:52 AM
bama29fan's Avatar
bama29fan
slight vibration
I noticed a slight vibration yesterday....
happened when i was backing in at work. I had the wheels cut to the right about half way and when baking up i felt a slight vibration. it wasnt constant...it would virbrate like three times and and stop and start again after baking another 5 feet or so. dont hear anything...just feel it
i thought i felt this a couple months ago while driving slowly forward waiting to pull out in to traffic...again the wheels were cut to the right. at the time i just passed it off as bumps in the road.
Any ideas?
Old Mar 30, 2010 | 11:15 AM
just another truck's Avatar
just another truck
Where did you feel it?? Steering wheel, or seat?
Or brake pedal?
Old Mar 30, 2010 | 11:19 AM
vans's Avatar
vans
I had similar problem last week, it turned out to be a bad serpentine belt
Old Mar 30, 2010 | 11:37 AM
bama29fan's Avatar
bama29fan
i believe it was the seat...i'll play with it some at lunch and see if i feel it in the wheel also.
Old Mar 30, 2010 | 01:10 PM
bama29fan's Avatar
bama29fan
i couldnt get it to do it again at lunch...but next time it does i'll pay more attention to where i feel it....
could it be something woth the brakes or maybe a wheel bearing? with the limited info i've given you it probably impossible to tell....
But you guys are good......
Old Mar 30, 2010 | 01:25 PM
just another truck
I would love to give you a bunch of answers, but I am hoping to learn the when so that I can help. Is this a full blown vibration, or a thump?
Old Mar 31, 2010 | 07:45 AM
bama29fan's Avatar
bama29fan
it's kinda like something is rubbing and it feels like a vibration...rub,rub,rub then it stops for like a full wheel rotation and rub,rub rub, again. thats why i was thinking something with brakes for wheel bearing? hopefully not involving the diff or anything more serious.
i didnt do it this morning???? but i was running late and in a hurry.
Old Apr 1, 2010 | 02:05 AM
1999SuperD's Avatar
1999SuperD
To me it sounds like the carrier bearing in the drive shaft cause mine does the same thing but i havent got the time to fix it so i just drive around the vibration. I would crawl under the truck and look at the bearing and grab the drive shaft at the bearing and see it you can wiggle it up and down. If you can then i would replace it.
Old Apr 5, 2010 | 12:42 PM
bama29fan's Avatar
bama29fan
Or brake pedal?
Felt it today...it was in the seat. only feel it when going really slow.
usmcBTC
Nov 13, 2023 09:10 AM
CountryFried
1997 - 2003 F150
Dec 1, 2010 07:14 AM
brian Felts
Aug 4, 2010 11:19 PM
DOUG5G
Aerostar
19
Oct 9, 2007 02:11 PM
