IDM 140 volt mod questions
Old Mar 29, 2010 | 11:49 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Right now at 180 degree oil temp at idle I am seeing 1.250 ms injector pulse width.
Injector control pressure is 500 PSI.
And each injector is injecting 8 cc's of fuel.
Stock 97 engine with a 120 volt IDM.
If I do the 140 volt mod, does the injector pulse width get shorter?
Old Mar 30, 2010 | 06:44 AM
Hussler's Avatar
Hussler
I believe from a computer standpoint (PCM) the pw is the same.
From a mechanical standpoint the injectors fir a bit quicker.
Here is some reading on it ... 7.3 Power Stroke IDM
Old Mar 30, 2010 | 02:22 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Here is another links that maybe helps you:
http://www.shol.com/shadow_tech/idmmod/
Powerstroke Diesel IDM mod
Old Mar 30, 2010 | 03:19 PM
Talyn's Avatar
Talyn
From my understanding its an efficiency thing on the 120 vs the 140 volt IDM.
I dont think the PCM knows, thats to high of voltage than you'd want to send to send to the PCM.
Old Mar 30, 2010 | 09:01 PM
Dave Sponaugle
I have been reading everything I can find, just wondering what differences I am going to be seeing.
I plan on theis mod shortly, so I guess I will do a couple wide open test runs with the data logger both before and after the mod to see what shows up.
Old Mar 30, 2010 | 09:11 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Good idea and post the results.
Old Apr 2, 2010 | 04:30 PM
powerstoked!'s Avatar
powerstoked!
hey guys, I posted a question on socaps.com about this and never got an answer. Anybody who has done the IDM 140 mod on an OBS(IDM 100 or 110), what were the changes to fuel economy? Currently I am getting 16-18city and 19-21 hwy. I don't want to sacrifice fuel economy if at all possible, which is why I don't want to do injectors. Future mods include intake, 4" exhaust (I already have a 3"dp), and a switchable chip(I have a dyno sources inc. single stage now). With the economy mode on my future chip, and the intake, and exhaust upgrades, I want to see up in the 20's for fuel economy... So yeah, if anyone has done it and seen a drop or gain in fuel economy, I would appreciate the info. TIA guys!
Tugly
113
Jan 14, 2016 09:41 AM
SpringerPop
Nov 20, 2013 08:07 PM
Visseroth
93
Jun 19, 2009 05:14 AM
mustang_gt_350
Nov 21, 2007 03:28 PM
powerstrokefreak
Jan 21, 2006 02:20 PM
