Sponsored by: Auxito
changing studs
Old Mar 29, 2010 | 08:44 PM
93 mix 'n match's Avatar
93 mix 'n match
changing studs
anyone want to tell me how to change the studs on my truck? front and rear.
Old Mar 29, 2010 | 08:55 PM
fordf150farmer's Avatar
fordf150farmer
just curious, but what is wrong with your studs?
and i have know i dea, but i would assume either change the rear axel shafts, and the front hubs, or a BFH.lol i dont know of any other way, but i have never done it either.lol
Old Mar 29, 2010 | 09:06 PM
93 mix 'n match
well old age got the best of them and they stretched out, making all the holes on the rims egg shaped. so i got new rims, new tires, new studs and lugs. Thursday im going to my buddys house who has a full air set.
all i know is it requires a good impact wrench. thats all ive heard lol
Old Mar 29, 2010 | 10:26 PM
93 mix 'n match
alright i got it! thank god for my dad who was a mechanic many years ago!
there pressed in. so its "knock the old ones out a press the new ones in" simple! i guess ill make a vid of it for my fellow FTE members.
Old Mar 29, 2010 | 10:28 PM
steve(ill)'s Avatar
steve(ill)
you put a punch on them and drive them toward the center of the truck and they pop out... the new studs have splines on them right?? you push the new stud in as far as it will go, then put the nut on and use the impact on the nut to pull the stud thru the flange. when your half way thru, take off the nut and put 4-5 washer on the stud and put the nut back on and pull the rest of the way.
Old Mar 29, 2010 | 10:32 PM
93 mix 'n match
i was gonna use some washers from the get go to pull it all the way through the first time.
