help with hpop install
Old Mar 29, 2010 | 07:47 AM
themicksterf250's Avatar
themicksterf250
Ok so I just intstalled an adrenaline hpop, diy inj, and a reg. Ret fuel system. On my 96. I have a problem with keeping oil pressure up after the truck is shut off and sits for more then 5 min. If I try to star it the oil pressure gauge reads on the dash reads nothing untill I crank wit for about 5-6 revolutions then it picks up oil pressure and fires right up. What gives?? The instructions with the adrenaline are kinds of vauge. Was there anything else I needed to put in the adrenline from the stock hpop besides the fittings? I left out the spring and that stufff from the stocker as per the the instructions. Any ideas??
Old Mar 29, 2010 | 09:47 AM
MagKarl's Avatar
MagKarl
I'd guess you still have a significant amount of air to purge from your HP oil system for sure, and possibly your fuel system since you've modified both of them. Is the HPOP reservior full?
Old Mar 29, 2010 | 10:20 AM
themicksterf250
Yes the hpop res is full and we mainuallu filled the rails. Once it starts then it keeps pressure and idles fine. But shut it off and let it set. No imediate oil pressure
cope1972
May 17, 2014 11:32 AM
jpcjguy
Aug 28, 2012 11:41 PM
kupaa
19
Nov 22, 2009 11:09 PM
Vinford
25
Oct 8, 2009 10:26 AM
PaysonPSD
29
Apr 10, 2009 02:35 PM
