I know this has been touched before, but couldnt find any pictures.
Looking to see some pictures of f250 f350 with a roof rack mabey some KC lights or soemthing on top. trying to see if thats what i want next
I've considered adding a rack, and here's the **** part of me: IF i do it, I'll remove the headliner so that I can mark and drill the roof so that I can have welded in small steel cylinders which have been drilled & tapped. This way, I can remove the rack if needed without any worry about leakage in to the cab. I had some pics; I'll try to dig them up and post them. If you look on 4x4 & desert racing forums, you'll have better luck, even though Super Dutys aren't used much.
