Sponsored by: Auxito
2000f150 problems HELP
Old Mar 28, 2010 | 05:02 AM
jl2680's Avatar
jl2680
i have a problem with my f150. the overdrive light flashes and wont shift and it blows the power point fuse 23 i replace the fuse and it runs fine the light for overdrive stops flashing and shifts fine.when i drive it for 5min it blows fuse again. any sugesstions?
Old Mar 28, 2010 | 09:01 AM
1912barry's Avatar
1912barry
Take the plastic stearing column part off the inside of the truck and locate the wires going to inside of the shifter leaver thats goes to the button, The way that it is routed it rubs the insulation off the wire at the shifter pivot point. Just rap some elect tape and problem solved.
Old Mar 28, 2010 | 09:33 AM
projectSHO89's Avatar
projectSHO89
No. F23 is unrelated to that issue which will blow F29, not F23.
F23 blowing is usually due to an O2 sensor harness laying on the exhaust or against a front half shaft (if 4X4).
Power feed from F23 also is used to operate the transmission's solenoids. When the fuse opens, the PCM detects a "CIRCUIT FAULT" for the tranny and flashes the O/D light (in addition to everything else that goes wrong...)
Old Mar 29, 2010 | 12:32 PM
jl2680's Avatar
jl2680
yes it was the 02 sensor,the exhaust place pushed the convertor shield in to
the 02 wires and shorted thme out.runs fine now. thanks for help
leadpoison
1997 - 2003 F150
Feb 23, 2013 10:54 PM
leadpoison
Electrical Systems/Wiring
Feb 23, 2013 05:34 PM
rollinginmudgirl
Nov 5, 2009 05:58 PM
jaymx401
1997 - 2003 F150
May 28, 2008 08:16 AM
94MustangGT
May 19, 2008 11:38 AM
