Clutch Question
Old Mar 27, 2010 | 08:39 PM
mhenneboehle's Avatar
mhenneboehle
Clutch Question
I have a 1994 f350 supercab dually 2wd and when i turn the truck off the clutch clanks. i was told it is the springs in the dual mass flywheel. if i replace the clutch can i go to a normal flywheel setup. was also told the dual mass was to prevent crank from breaking but may people run normal flywheel. What is your guys' take on this?
Old Mar 27, 2010 | 09:11 PM
starmilt's Avatar
starmilt
quite a few have swapped to a solid flywheel, some have even made the dualmass solid from what I hear. You wind up with some tranny noise at low rpm that everyone calls gear rollover noise. It supposedely doesn't hurt the tranny, it just sounds like it.
