I have always got 200 miles from full to the red zone on my gas gage till now. Now I get 230 and over and that translates to 18 MPG and up with city driving. The only things that are different that I can think of are that I changed my CPS in January and switched over to synthetic rotella in December. Back in late February I goofed and left the plug out of my HPOP and lost all of my oil and the only place open was a Mobile gas station and they had Mobile 5w40 synthetic so I had to use that. It was after the switch to the mobile when I started to notice the difference in mileage. Can the synthetic make that much of a change in mileage? Or is it something else that I am missing?
I've heard people talk about gains in fuel economy when switching to synthetic, but that's a pretty big jump. Did you change your driving style at all?
I was thinking sensor too but I did not see any gains after replacing the CPS until I put the Mobil in. I was thinking I had a loose wire thats good now or something like that. And like I said before I never did see a diff between winter and summer fule around here.
You might be onto somethig there. I have noticed the oil leaking out all over the place is now a lot more cleaner looking. So its cleaning things up and thiner to get to the injector past any crap. This is the stuff I have used. http://www.mobiloil.com/USA-English/...uck_5W-40.aspx
What size tank are you calculating that on. My truck has a 17 gallon tank both front and rear. At 230 miles per tank that translates to around 14.5 miles per gallon.
I think I have 20 Gallon tanks but I am going by how much I use. If I get to E and it takes 13 gallons to top it off at the pump than I know I used 13 gallons. And 13 is normally what I put in after I get to the red. 230/13=17.692
