I need to find out if my build date is before/after March 1, 1999. The sticker inside the door post is faded and peeling on the top left corner, and the majority of the sticker is illegible. Is there any other easy way to find out which version of the truck I have?
Why do you need to know? Is for wheel bearings?If yes you can tell if its the earlier model by measuring the hub thickness.The easiest way to check is too take a 10mm wrench and see if it fits on the edge of the hub,If its 10mm its the early model,13mm its the newer model.You can use the newer one on the older model but you have to buy a rotor for the newer model.Which is usually cheaper than the older hub alone.
