Sponsored by: Real Truck
Build Date Help
Old Mar 27, 2010 | 06:24 PM
splice1985's Avatar
splice1985
Build Date Help
I have a 99 F350 4x4 SRW CC 7.3L.
I need to find out if my build date is before/after March 1, 1999. The sticker inside the door post is faded and peeling on the top left corner, and the majority of the sticker is illegible. Is there any other easy way to find out which version of the truck I have?
Old Mar 27, 2010 | 10:41 PM
Franko72's Avatar
Franko72
Molon Labe
This link may help answer your question. A Oasis report form Ford will also tell you.
https://www.ford-trucks.com/forums/9...late-99-a.html
Old Mar 27, 2010 | 11:34 PM
mnpowerstroke99duty's Avatar
mnpowerstroke99duty
Why do you need to know? Is for wheel bearings?If yes you can tell if its the earlier model by measuring the hub thickness.The easiest way to check is too take a 10mm wrench and see if it fits on the edge of the hub,If its 10mm its the early model,13mm its the newer model.You can use the newer one on the older model but you have to buy a rotor for the newer model.Which is usually cheaper than the older hub alone.
