410 begins..
Old May 30, 2010 | 01:23 PM
  #31
73 ford guy's Avatar
73 ford guy
Yeah I will never cut another intake dont worry. I never ended up getting that other engine. I went back for a second look after finding out block and head #s could of been anything from 390-428. We looked at the crank and it was 2u... A 390! Block and head casting were 68 so someone thought they had a gem. My 390 went back to the machine shop and it's junk. We test fit the 428 crank because the 390 one was standard bearing as well as the 428 so it was a direct bolt in. Turns out the pistons were a low compression truck one and they would work with a minimal .07 skim off the top. Problem was the cylinders had water damage that couldn't be honed out due to improper storage over the past couple months on my part and needs to go to a .040 bore. We found that it was the block that was decked not the heads so I would have to shave the sides of the heads to match intake again. Justfor an extra kick to the nutz the new crane cam spun a lobe even after carefull assembly with lube and zinc oil additive and higher rpm speed on initial fire up for proper break in. Too much machining costs when I can get another 428 block bored .030 over with matched cj pistons for 1000$ just a ferry ride away from me. I know ive changed my mind a few times on this build but it's alot of back luck and lack of knowledge on my own and others fault that has over complicated this whole thing... I appreciate help from you guys with your knowledge on this stuff. As I say again this is not my strong point and I'm just trying to gain as much knowledge as possible to make it right.
Old Jun 1, 2010 | 06:28 PM
  #32
73 ford guy
So now I'm looking into some info on best cam choice for this .030 428 block I'm getting with cj pistons. The compression should be about 10:3:1 and I dont need any vacuum for power brakes as I run hydro boost. I'm looking for bottom end grunt power. My tires again are 44''s with a 5:13 gear ratio. I had a crane 343941 that spun a lobe so I'm looking for something similar as crane went out of business. Any suggestions on what you guys run ?
Old Jun 1, 2010 | 08:34 PM
  #33
73 ford guy
Talked to Comp cams tech and punched in all my motor details and we came up with a 33-238-4. Link ->Comp Cams 33-238-4 Camshaft
It showed max hp at around 400 @ 4500rpm
max tq at 550 @ 2500 rpm
Seems to be pretty decent #'s
Old Jul 10, 2012 | 01:30 AM
  #34
FordmanShane's Avatar
FordmanShane
not bad..did you pick this cam up?
Old Jul 10, 2012 | 08:50 AM
  #35
MIKES 68 F100's Avatar
MIKES 68 F100
ford guy
give me exact motor specs
cam
carb
intake
heads
C/R
i'll run it on desktop dyno 5 and post results it will give you a good idea of HP/TQ
Raptor119
Apr 29, 2015 03:40 PM
1975FordF250
May 17, 2014 10:50 AM
caspermj
Jan 12, 2012 03:20 PM
tater_51
17
Feb 21, 2010 05:48 PM
Annihilator
17
Apr 19, 2005 09:11 PM
