6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
trouble code po40d/egrt sensor A circuit high
Old Mar 27, 2010 | 11:12 AM
pedal smasher's Avatar
pedal smasher
Hello, This is my initial visit to this site/forum. I have a trouble code PO40D appear on my scan tool. According to the manuel, this truck engine carries 3 of these particular sensors. Does the e.g.r.t. sensor A circuit high indicate location of the faulty sensor, because the other 2 sensors indicate low and range/performance. The engine will run, but stomping the gas pedal has very little response and the turbo blower responds with only half power. I can get place to place but only slow at the truck's discretion. All 3 sensors are supposedly interchangeable, but location is my problem. Also, my truck is under the 100,000 mile warranty, but is this a wear item or a warranty item? This code stands for Exhaust Gas Recirculation Temperture sensor "A" circuit high. All help will be appreciated. Thank-you.
Old Mar 27, 2010 | 12:31 PM
Tom's Avatar
Tom
Warranty item!!! This is NOT a normal wear thing!
Bring it in and let the dealer handle it, they will not charge you for the repair.
Old Mar 27, 2010 | 04:23 PM
senix's Avatar
senix
It is a warranty, sounds like the EGR electronics....it is also an emissions component too!
Old Mar 27, 2010 | 04:57 PM
PSDx3's Avatar
PSDx3
I had the same code at 10,000 miles. Dealer replaced the egr valve, took about 30 minutes. They said it was stuck closed.
Old Mar 28, 2010 | 07:46 PM
SrMasterTech's Avatar
SrMasterTech
P040D
The DTC P040D is the EGR temp sensor A. There is also a EGR Temp sensor B. The 3 sensors you mention in your posts are the EGT is the Exhaust Gas temp sensor and there are 3 of them. The EGR Temp sensor A is located in the Right hand exhaust up-pipe to turbo inlet. EGR Temp sensor B is on the outlet of the vertical EGR cooler. The 3 EGT sensors are pre, in and after the DPF. All temp sensors are covered by emissions warranty. In the worst case, the sensor gets siezed in the pipe. I have had to remove the cab to replace the RH up pipe for sensor siezing or breaking in pipe.
Old Mar 29, 2010 | 05:08 AM
ruschejj's Avatar
ruschejj
I had the EGT sensor #3 fail on me and I had the same issue, I could drive/tow and get around but the engine did not run the way it's supposed to. I was lucky that it was the easiest one to get at. Sat at the dealer for 20 minutes and was good to go. Good luck.
Old Aug 14, 2010 | 11:53 PM
borcht warrior's Avatar
borcht warrior
Hey SR
What is the best way to get to the sensor in the RH uppipe? Can I get to it with hand tools in the campground?
Sgt93
6.7L Power Stroke Diesel
Feb 5, 2018 12:48 AM
oneupfx4
Jun 16, 2017 05:47 PM
DieselDenny
Jan 31, 2017 08:51 AM
Rowcrop
Nov 14, 2016 10:20 AM
gage52
39
Oct 17, 2013 06:47 PM
